Badger5Sky Insurance
Results 1 to 8 of 8
    Oct 2012
    79
    TFSi Intake Manifold Flap 06F 133 482 - What's it do ???
    Took the Throttle body/motor off today to give it a clean out and noticed another motor unit towards the rear of the intake manifold.
    This has the P/N 06F 133 482 and appears to be called a 'Intake Manifold Flap'.
    Can anybody explain what this does, when it operates and what the symptons are likley to be on a faulty or dirty unit.
    I coudn't see any hoses going from/to it, so assume it drives something within the manifold.
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    726
    On another note, what's your mileage and how bad was the carbon build up??? My car keeps throwing an intermittent code up for TB and Map sensor and was considering getting the intakes removed and having the valves etc cleaned
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    Oct 2012
    79
    Just clocked 90K and the Throttle Body was quite clean.
    A few squirts of carb cleaner and a wipe and it was as good as new.
    Also took cam/rocker cover off and the cams and surrounding area were remarkably clean considering mileage. No wear on cams either.
    Oct 2012
    79
    Anyone have a clue what it does ?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Quote Originally Posted by Scott.T View Post
    I don't know what it does on a TFSi engine, but what it does on a 3.0TDI, most of the time, is break, leaving the owner with a large bill.
    On a more serious note, if it is what I think it is, the motor you are referring to is connected via a little plastic pushrod, to a spindle-mounted flap inside the inlet manifold. This flap, or inlet manifold swirl flap to give it its full title, is a device for altering the airflow in the manifold to optimise combustion.
    Over time, the mechanism can wear, sometimes causing the pushrod to be detached (usually at the spindle end) and the engine management light to come on. This is most prevalent in the 3.0TDi V6 engine, but can happen on others too, I imagine.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Oct 2012
    79
    thanks for that.
    it it active at anytime adjusting in relation to throttle angle.
    is it used just during warm up.
    i will check the rod but i have no error codes.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    thanks for that.
    Not sure; think it might just be during warm-up.
    Oct 2012
    79
    Well checking the car while hot yesterday, the intake flap arm driven by the motor wiggles when you take the keys out of the ignition.
    When the engine is running the arm pushes the flap in a similar fashion to how you would expect the main throttle butterfly to work i.e more throttle = more movement on the Intake Manifodl / Swirl flap.
    Alot of the clicking/buzzing you get when the engine has just been turned off, and key's removed, seems to come from this switl flap and the Throttle Body.
  1. Replies: 190
    Last Post: 1 Week Ago, 17:38
  2. Problem with: motor for intake manifold flap malfunction 19559 v157
    By kaos in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th December 2011, 14:59
  3. Help - Part Number for Motor Intake Manifold Flap - EGR Valve
    By miszka20 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd July 2011, 20:02
  4. Intake manifold flap
    By 347 in forum VCDS (formerly VAG-COM) forum
    Last Post: 22nd November 2009, 23:12
  5. *fault* Motor for Intake Manifold Flap
    By a3guy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th November 2007, 12:54
