Sky InsuranceJMB Retrofits
Results 1 to 9 of 9
    Nov 2012
    10
    2005 a4 2.0 tdi car vibrating/shaking in whislt stationary
    Hi
    I was wondering if anybody has the following problem with their a4 2.0tdi-
    1.vibrating/shaking whilst stationary
    I have depressed the clutch and the car still shakes. The revs are constant at about 9000, no loss of power the revs don't hunt. There is no smoke or warning lights.
    I have read somewhere that it could be the flywheel, a eletrically controlled mounting (does this model have one), dirty connection on the injectors or the injectors themselves?
    Any help would be appreciated.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,680
    Revving at 9000rpm might have something to do with it, heheheh!
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Molnboman's Avatar
    Is it noticeable in first and second gear too on accleration?
    BR
    A
    Nov 2012
    10
    No I'd say its only noticeable whilst stationary.
    I meant 900 rpms.
    dieseldoug's Avatar
    Oct 2012
    Aberdeenshire
    240
    whats the miles, its possible an injector not firing at low RPM, is the power still there while driving?
    If you are using supermarket fuel get shell or BP and try that (supermarket fuel no too good) if the problem is still there go to your local DIY shop and look for diesel fuel injector cleaner, if all fails look at dealer for the trouble shooting.
    Nov 2012
    10
    there is no loss of power and I only use shell or BP. So it couldnt be a dirty EGR valve or damaged mounting?
    Molnboman's Avatar
    Don't think it's your dual mass flywheel y the sounds of it then....your wallet will be relieved...not sure what else to suggest...do you have a friendly garage who will run a diagnostic check for you.
    Kee us in the loop.
    BR
    A
    Nov 2012
    10
    will do
    Jul 2012
    56
    Possibly either dirty EGR valve or engine mounts are knackered like mine, if you get it scanned it should come up with an engine mount solenoid fault if it is your engine mounts
  1. Car slightly shaking at idle, help before it gets worse.
    By Mason-A3Sport in forum Diesel forum
    Last Post: 20th May 2009, 14:18
  2. 2004/2005 A3 2.0 TDi s-line DSG CO2 Emissions?
    By RS84 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th October 2008, 16:27
  3. vibrations/shaking when driving off
    By abdus in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th August 2007, 17:55
  4. Car vibration when accelarating
    By totopsgr in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th March 2007, 19:15
  5. tdi avant - vibration + smoke
    By barclay03 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th January 2006, 19:39
