Sky InsuranceBadger5
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By thuss
Thread: a4 2.0 tdi steering wheel/serpentine belt
    Nov 2012
    10
    Hi
    I've got a 2005 a4 2.0 tdi. When I fully lock the steering wheel right, left or approaching fully locked I get strange noises coming from the alternator area.
    So the other day I got a friend to lock the steering wheel whilst I looked at the serpentine belt. As he turned the wheel I could see the belt physically jump at the alternator pulley.
    Can anyone suggest if its the tensioner thats gone? or can I raise the alternator so that the belt is tighter as I believe the tensioner is a self adjusting tensioner? Or is it some other pulley?
    the tensioner looks like its working moving from side to side I estimate 5- 10mm.
    Thanks in advance
    Oct 2011
    Cumbria
    89
    Is this the cow 'moo' type noise you speak of?
    A4 Avant tdi S-line
    Nov 2012
    10
    I would definitely say as I turn the steering wheel a series of squeaks with maybe a very very low moo underneath (I dont know if the moo is due to the steering being turned with the car in a stationary position)
    Dec 2006
    N.Ireland
    369
    I had a similar problem, was a failed pulley on the alternator that needed changed
    Dec 2006
    N.Ireland
    369
    Same one in this youtube clip YouTube
    Nov 2012
    10
    thanks I will have a go at it tomorrow, I appreciate the help/advice.
    27,014
    Well when was the belt & tensioner changed last?
    Nov 2012
    10
    Claudefrog you were spot on!!! it was the alternator pulley that was seized and it was seized in both directions.
    So changed the pulley sounds like an audi now. Really do appreciate the advice.
    One last thing when I rev the car (car is stationary and not in gear) and take the foot of the accelerator at the end of acceleration as the engine returns to idle theres a groan,has anybody had that before? I wish I could post the sound, btw should I start a new thread?
    claudefrog likes this.
  1. Tighten or replace serpentine belt A3 tdi
    By robtdi in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2011, 16:11
  2. Allroad V6 TDI serpentine belt routing
    By trumpetboy11 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 1st November 2010, 22:35
  3. pc steering wheels
    By badbaz in forum Video Gaming
    Last Post: 10th August 2003, 14:33
  4. Steering Wheel Remtoe for stereo?
    By AutoMatt in forum In-Car Entertainment
    Last Post: 8th August 2003, 08:07
