AH FabricationsEM Tuning
Results 1 to 9 of 9
    brian1970's Avatar
    Nov 2012
    Grid Lock Norwich
    21
    Engaging 1st gear problems on my S4 Cabro (2007)
    Hi folks, i have carried out a search but not found anything on this one.
    I purchased my S4 Cabro a few weeks ago.
    I took it for a extensive test drive and it was great
    Its only done 25K miles so its low millage for a 2007 car.
    Over the last week, its been difficult to engage 1st gear, it needs a good hard push.
    Nothing like engaging 2nd or 3rd while stationary. all other gears slip in lovelely.
    When stationary selecting 1st gear dosent slip in like it did when i originally purchased the car a few weeks ago.
    If i double clutch ( While Stationary) it then goes in fine, But 1st time i put foot on clutch and then try for first it needs a good push.
    I turned down another S4 that i test drove as it had this fault.
    What should i do ? can it be repaired or is this a common fault.
    The gearbox is the 6 speed.
    Brian
    AudiB7Jay's Avatar
    Nov 2012
    355
    Mine does it too I'm on 88k
    brian1970's Avatar
    Nov 2012
    Grid Lock Norwich
    21
    mmm I tried another S4 before i purchased this one, it had 77K on the Clock and had the same Fault, which is why i didnt purchase from dealer.
    Do you think its a linkage issue ? or is it the clutch ?
    g00se's Avatar
    Nov 2010
    Reading
    244
    mine had 23k 2yrs ago, and now is on 60k... (18k/PA - yikes!), and mine can be stiff to get into 1st.
    i normally just drop it into 2nd, and then push up 2nd to 1st and she slides in easier (oh-er missus)
    goose
    Current:
    '06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
    '72 Sunburst Yellow VW Karmann Ghia Coupe - 1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 black leather interior
    brian1970's Avatar
    Nov 2012
    Grid Lock Norwich
    21
    Its booked in at the Garage next week to see if they can sort the problem out, strange thing is that it doesent do it all the time, Last Weekend it did it all the time, this week its slid in OK. something is going on, but cant put my finger on it.
    Clutch bite seems to be really high.
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    1,908
    Is it different if the engine is hot or cold?
    JSD 2.59
    Synergy-Solutions
    brian1970's Avatar
    Nov 2012
    Grid Lock Norwich
    21
    no hot or cold, makes no difference
    Jun 2011
    Manchester
    227
    My 2.0T also does this very randomly. I do as Goose suggested above, put it into 2nd and then slide back up to 1st gear.
    My car has done 77k.
    2005 B7 A4 2.0T in Moro Blue
    Interior, Number Plate & Sidelight LED's from T8ups, 18" 9 Spoke TT Wheels.
    BGB Engine Code.
    Sep 2010
    Whitehaven, Cumbria
    56
    Im looking forward to seeing the answer for this.
    My s4 does it, i have a feeling it could be the clutch beacuse if i roll forward as i try to engage the gear it goes in no problem.
    I do hope its just the linkage though!!
    my cars on 106K
  1. A6 C5 1.9 tdi 1st/2nd gear problem
    By RizlaUK in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 17th January 2012, 21:02
  2. 1st and 2nd Gear problems after clutch change!
    By trophs in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd October 2011, 21:26
  3. S3 1st gear problem and strange noise....
    By sandwich1987 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2011, 22:07
  4. Audi A4 1996 TDI 1st gear problem :( Help !!!!!
    By slips in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th October 2004, 22:15
  5. S3 third gear problem
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th July 2004, 23:29
