Volks AutosBadger5
Results 1 to 8 of 8
    Jan 2012
    Lincoln
    138
    Oil pump failing symptoms on a tdi?
    Evening all I'm just wondering what the actual symptoms are of the oil pump failing on the tdi engines as mine is sounding get loud at the minute and were running out of options as to what's wrong with it at the minute.
    May 2011
    195
    When you say loud what sort of noise is it. You will get the red oil light on your dash if there's nee oil pressure I.e pump knackered
    Jan 2012
    Lincoln
    138
    It's a loud Tappy noise, I'm just trying to figure out if it will be the dreaded balance shaft oil pump problem but want to know what the symptoms are
    May 2011
    195
    What car is it buddy
    Apr 2012
    Oxford
    126
    I don't think the symptoms are loss of low-end power and smoking... i believe it is just the rattling noise, followed at some arbitrary point by the oil pressure light coming on and chunks of turbo flying everywhere (used to have an A4 with a BLB 2.0 TDI, so lived in constant fear of this for a while)
    If you want another possible lead on the rattle (to rule out the oil pump drive shaft), I heard what I thought was the rattle of expensive doom approaching, and it turned out that the air-con compressor had seized/died.
    May 2011
    195
    Could it be the chain rattling. Isn't there a piece that breaks off.
    North East
    607
    Quote Originally Posted by Gates View Post
    When I was told by my Indy that I had a rattling chain (BLB engine) i didn't believe him as I had been listening for symptoms for the previous two years. What actually happened is that my engine had quite probably been rattling for sometime but my ears had come to accept the rattle as the norm ( unlike my wife who said she could most definetely hear it rattling ). I caught my own engine in time and didn't need the turbo replacing but i did need the bearing shells replacing as not only was the chain rattling but the hex shaft had started to round off and hence although I had oil pressure it was getting low.
    Paul B7
    Apr 2012
    Oxford
    126
    Quote Originally Posted by fossie View Post
    Yeah, I think the bit that breaks is actually a silly plastic(!) tensioner/guide, which of course makes the chain go slack and rattle about and then fail in short order.
  1. 2.0 TDI oil pump / balance shaft failure?
    By P Crr in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2 Days Ago, 19:40
  2. following sticky 2.0 TDI oil pump / balance shaft failure? what year cars?
    By p1tse in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th April 2012, 17:24
  3. 2.0 TDI Oil Pump Failure?
    By danquattro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th January 2012, 11:08
  4. Trader Dispute - 2.0 TDI A4 S LINE, RE: OIL PUMP CHAIN.
    By Fahim in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 16th June 2010, 14:39
  5. 2.0 TDI Oil pump chain.
    Last Post: 23rd December 2009, 11:03
