Volks AutosJMB Retrofits
    Mar 2011
    S E Kent
    238
    Help in advance with cruise fit
    Ok hopefully I am fitting cruise on Thursday - I have it pretty clear in my mind just one thing really do I need to remove the slip ring to install the stalk?
    all of the guides I have read are for cruise and DIS
    i already have the stalk and he car has MFSW
    Many thanks
    2006 A4 cab
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    If you already have an MFSW then you just need to take our the airbag, wheel, slip ring and steering wheel control module. Put in the new stalk and put it all back. You will need a new lower steering wheel cowl though.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    Mar 2011
    S E Kent
    238
    Thanks- do i take care with how I replace the slip ring?
    2006 A4 cab
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    You should be fine, they are reasonably robust. Just don't use too much force.
    Nathan
