Results 1 to 8 of 8
    Aug 2006
    44
    MPG figures on 2.0T Quattro
    Went up north the other day to Preston from London and was driving sensibly, averaging around 80mph or was it 70 ;-) on the motorway. In 6th gear most of the way but no matter what I did I couldn't get her over 30mpg, is this normal? I would have thought I would get better then that....What do some of you guys get on a stretch in your TFSI Quattro's?
    A4 2.0T FSI Avant S Line Quattro - Phantom Black
    Nov 2012
    Worcestershire
    89
    That does sound low - mine does 32-33 at a steady 80 on the Motorway (goes up to 35ish at 70)
    Mine is a 56 plate (2007) 2.0T Quattro Avant Special Ed
    chrisa4quat's Avatar
    Sep 2004
    897
    My dtm remapped with hpfp etc does 36-38 on a run at around 70-75mph
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    Nov 2012
    Worcestershire
    89
    Quote Originally Posted by chrisa4quat View Post
    Bloody hell you must drive like Miss Daisy!
    hpfp?!
    Sep 2004
    897
    High pressure fuel pump. It's mapped. Decat full exhaust and air filter. I say there with my cruise on :-)
    Mar 2011
    112
    Recently did just under 1400 miles up to NW Scotland, round and back home and brim to brim over complete journey averaged 30.8mpg.
    Good mixture of Motorway and excellent A roads, travelling at about 80mph on Motorways and 60 to 70 ish on A roads. Never seems to be any different. Engine is BUL 220 BHP and Quattro transmission.
    Aug 2006
    44
    Thanks for all your replies.
    Where do I start to investigate a possible issue with it?
    Car is remapped by AMD, has the revised DV fitted and is serviced regularly. The PCV was also swapped out a couple of weeks ago.
    spider74's Avatar
    Feb 2012
    Scotland
    89
    when i had a boost leak my MPG went down to about 25mpg. Pretty common if you've just been remapped. Check the intercooler hoses and tighten them all up as a start? then an ebay boost leak kit might help (worth buying anyway)
    Also removing the cat or fitting a sport Cat seems to make a big difference on our cars. as much as 5mpg.
    Audi DTM edition, Sprint Blue, MRC remap, milltek, RS4 RARB.
  1. MPG figures
    By JCMCN in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th February 2010, 11:28
  2. MPG figures on a 2.5 tdi v6 avant
    By bad-vw-boy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st December 2009, 13:21
  3. The Results are in! - TDI 170 MPG Figures.
    By PJLarge in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th November 2006, 20:37
  4. DIS MPG figures
    By d5aul in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th May 2006, 10:09
  5. MPG for a 2.8 Quattro 30v
    By stebed in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th March 2004, 19:10
