Chris NottSky Insurance
    Dazmo's Avatar
    May 2009
    Leicestershire
    1,775
    Faulty socket or something else?
    In my car i have both an in car camera and GPS camera Detector.
    I just plugged them both into the lighter socket as i normally do and my camera just popped (sparks flew out of it and it started to smoke)
    I unplugged everything and just tested the camera on its on in the socket, it keeps turning on and off, so its either damaged or its the socket.
    Now my question is, if this had blown the fuse then surely the camera would not be powered when i plug it in, but it seems to still draw power.
    Does anyone know what this could be? as it still drawing power i am assuming its not the fuse, could it just be a fault with the lighter socket or possibly a short in the wiring?
    Anyone know what i should check or how to check?
    Maritus Blue Audi A4 3.0 V6 S-Line TDi 275bhp, 585nm Torque
    alpesh26's Avatar
    Mar 2011
    264
    It sounds like the camera is damaged. I'd try plugging in a phone charger or something else to the cig lighter socket (something that wasnt connected when things went bang)You could try finding the wires to the cig socket and connect up a multimeter and see if you get a fluctuation in the voltage.
    Audi A4 B7 1.9TDi SE | Auto Lights, Wipers & Dimming Mirror | Cruise Control | DIS
    Mod's so far: Ambient light, Cupra R splitter, 4300k HID's, Painted Brake Calipers & Hubs, Dice Electronics iPod & Aux, Leather Armrest, Interior, Sidelight & Number Plate LED's, Curry Hooks, Tie Downs, Ambient Footwell LED's, Footwell Lights, Shadow Chrome S-Line (RS6) wheels, Mudflaps, Votex Rear Diffuser, RS4 Rear ARB
    Dazmo's Avatar
    May 2009
    Leicestershire
    1,775
    Quote Originally Posted by alpesh26 View Post
    Hi, well i have checked the fuse and its fine and i have tested using my iphone and charger, again all seems fine.
    I bought a battery/alternator tester to check the current and to see if any of these could be the culprit.
    26,762
    Sounds like a camera/loom issue to me if standard phone charger works fine, maybe something shorted on the loom or when inserted into the socket, not allot can do tbh if socket is ok, apart from claiming warranty if camera is under or buying another or maybe alternative.
    The 12v socket shouldnt short across given location of the -/+
    Dazmo's Avatar
    May 2009
    Leicestershire
    1,775
    Think i have figured out the problem.
    I basically mixed up the power adapters for the camera dvr and speed camera detector.
    So the camera overloaded and blew and the speed detector does not draw enough power to boot up, a quick change of the cables and the speed camera detector now works fine, however the damage to the camera is permanent.
    Although i don't think it helped that i plugged it all in befor starting the engine, could have been a power surge aswell.
    Anyway got my battery tester and the light came up as yellow, so looks like my battery is low, also the alternator showed up as yellow which does not sound good either.
    26,762
    Stick a ctek on battery for a weekend if possible, brilliant chargers, then check battery etc.
  1. Tracking? or something else?
    By jackj in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th April 2011, 14:12
  2. MAF or something else?
    By StraightSix in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd July 2010, 11:19
  3. Megs wheel brightener or something else....
    By S3 Rav in forum Detailing
    Last Post: 28th February 2010, 18:29
  4. Something else i've just noticed about the new VED bands!
    By Nickynibbles in forum General Chat
    Last Post: 22nd September 2008, 13:11
  5. battery or something else?
    By imported_Nigma in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2005, 15:23
