EM TuningAH Fabrications
Results 1 to 8 of 8
    brian1970's Avatar
    Nov 2012
    Grid Lock Norwich
    21
    Question Cabro Rear centre LED light problems (sorry)
    First up i would like to introduce myself to the Forum.
    I did a Google search for the fault i have and i found myself here
    I have just purchased a S4 Cabro (pics soon)
    THe rear centre LED light keeps faulting, It does work now and again, and sometimes it works but is dim ?
    So im thinking it must be a faulty lead or connection ? As LEDs last years (this is a 2007 model)
    First up im going to check and clean connections, but would like a `How to` to take the Boot lining out to access the light as i dont want to go in like a bull in a china shop and possibly bust off all the little bits that hold in the lining
    Any help would be really appreciated
    Brian
    Dec 2011
    Glasgow
    187
    I would guess there is a broken wire in the loom somewhere generaly the break occurs in the flexible conduit between the boot lid and car
    To remove the boot trip open the boot
    Remove the warning triangle from the holder once this is out you will see 2x Allen key bolts undo these and the holder comes out
    Next look by the interior pull handle you will see a screw undo the screw
    Then by the boot lock gently pull the black plastic cover off
    Then gently tug the edges of the boot lining to release the clips
    There's push in clips all the way round the boot lid lining so gently tug these
    Once released it should come off
    A4 B7 2.0ltr TDI Cabriolet
    Mods
    Puddle lights Illuminated cup holder Cd changer in glove box Interior lighting led upgraded
    Full VCDs
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    749
    As Gaz said...
    Although it's worth noting that removing the lining will (from what I can remember when I had mine off to fit LED resistors) will probably not give you access to the LED bar. It may be the case that you can push it out from the inside, hopefully...
    Wish you the best of luck! And let us know what you find...
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    brian1970's Avatar
    Nov 2012
    Grid Lock Norwich
    21
    Hi Folks thank you so much for the detailed explanation of the removal, ill have a look this afternoon to see what i can find
    Dec 2011
    Glasgow
    187
    I've never taken the light bar out the boot lid but you an access the wiring to it
    I am guessing that you can unscrew it and it slides out
    You can get to the back of it though with the boot lining out
    Mods
    Full VCDs
    Dec 2006
    Herne Bay, Kent
    53
    Quote Originally Posted by brian1970 View Post
    Brian
    Had this on my 56 cab, tried cleaning etc but eventually replaced the unit and not seen the problem since.
    Abb
    Abb's Avatar
    Sep 2009
    Teesside UK
    316
    Hi Brian1970, had exactly the same problem on my motor. Stripped it, cleaned connections etc, worked momentarily, and then back to the fault again. Ended up removing and replacing the brake light, think it was about £30ish from TPS, never had any problems since!
    Audi S4 quattro cabriolet in dolphin grey metallic, Audi exclusive crimson red leather/black piping, red hood, carbon inlays, RNSE, tiptronic gearbox with paddleshift, electrically adjustable & heated seats, 6 disc multichanger, DVD multichanger, monitors in headrestraints, xenon headlights with power wash, cruise control, folding door mirrors, storage pack, 19" OE VW Touareg wheels with 25mm spacer/adapters all round, non res cat back quad tipped Milltek exhaust, lowered 30mm on H&R springs
    brian1970's Avatar
    Nov 2012
    Grid Lock Norwich
    21
    Thanks Abb, I havent taken it out yet as it hasnt Faulted over the weekend, but its bound to do it again soon.
    Dosent sound too expensive to change
  1. Retrofit 2010 A3 Sportback Rear LED Light problem
    By 210_MIH in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th August 2012, 11:57
  2. Number Plate LED Lights - Problems!
    By MattyW19 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th September 2011, 12:48
  3. Replies: 6
    Last Post: 23rd August 2011, 12:48
  4. Help Rear number plate light problem A3!!!!!!!!!!!
    By johnnysalv in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th May 2010, 23:02
  5. Replies: 2
    Last Post: 18th September 2008, 10:19
