Badger5Chris Nott
Results 1 to 7 of 7
Thread: Door/wing issue
    May 2011
    195
    Door/wing issue
    I have noticed that the drivers catches the wing at the bottom and that the shut line isnt straight - or doesnt seem to be all the way down. The wing seems to line up with all the lines on the bonnet etc.
    The question is is there any way to adjust the door - i need to pull the door back a couple of mm so when i open it it clears the wing...
    Thanks in advance
    Lee
    North East
    607
    Quote Originally Posted by fossie View Post
    Thanks in advance
    Lee
    Sounds like your car has had a bump and a bad repair ?
    May 2011
    195
    Yeah more than likely Paul but it was bought hpi clear and only noticed this now
    North East
    607
    Our daughter had a similar issue on a Cat D Focus which was a result of the door pillar being bent.
    i could never really sort the issue. She ran that car for four years with NO issues and even sold the car for a little more than she paid.
    Good old e-bay !
    Good luck with your car.
    Paul B7
    May 2011
    195
    Ive looked at the door Paul and work out that if i used some 2mm washers i could space the bracket out on the door just enough
    34
    You need to be careful of the alignment with the door catch. Pushing the bottom of the door aft will rise the rear relative to the catch.
    May 2011
    195
    Quote Originally Posted by GarJE View Post
    thanks. If needs ill be adjust the door catch as well. I'm sure they can be adjusted
  1. 2004 A3 3 door - wing mirrors
    By Naj in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th November 2011, 12:27
  2. door blade issue on Allroad
    By monkeyboyuk in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd April 2011, 20:22
  3. Door handle issue and part wanted
    By gaz71 in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th February 2010, 20:14
  4. Wierd door locking issues.....
    By p14va in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th December 2007, 13:01
