EM TuningAH Fabrications
    madstaff's Avatar
    Apr 2012
    74
    2.0 TDI PD 16V injector removal tool.
    Anyone used the tool that looks like this - Common Rail Diesel Injector Extractor For VW Audi TDI VAG | eBay
    If so, how does it attach itself to the injector body to enable you to pull it out with the slide hammer??
    I'm gonna have the No1 injector out my car to clean and replace the seals as the injection quantity deviation reading in Block 13 for cylinder 1 is reading considerably higher than the remaining 3 injectors.
    Just amassing tools to do the job, bought an ultrasonic cleaner the other day so i can clean the nozzle whilst its out, and want to be prepared in case the injector is being stubborn and wont pull out out easily.
    Thanks.
    Audi A4 Avant 2.0TDi S-Line Special Edition
    Apr 2012
    202
    The two prongs go into where the bolts are that hold the injector in the head. Remove both bolts and the small nipple where the rocker acts on the injector. insert the prongs pull the tool up till you feel the barbs catch then wind the center down onto the top of the injector spring tighten up the lock nut attach slide hammer and remove.
    madstaff's Avatar
    Apr 2012
    74
    Easy as that eh??
    Does it damage the injector body in any way??
    Was gonna arm myself with the tool just incase the injector i want to remove is being stubborn.
    Apr 2012
    202
    No damage to the injector is caused. They never tend to stick in the head tightly always come out fairly easy.
  1. Injector removal tool
    By Eddieg in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th June 2012, 18:59
  2. 2.5 TDI V6 Injector Removal - Help Please!
    By Magnet in forum Diesel forum
    Last Post: 1st February 2010, 22:41
  3. V6 TDI - Injector Removal Tool & Drain Filter Help !
    By RogerTDI in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th November 2009, 20:25
  4. mini-ISO Pin removal tool
    By asifgillani in forum In-Car Entertainment
    Last Post: 14th March 2005, 17:22
  5. anyone in SOCAL has radio removal tools?
    By fod in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th September 2004, 07:42
