Sky InsuranceJMB Retrofits
    Sep 2010
    Whitehaven, Cumbria
    59
    Armrest retrofit
    Hi Guys,
    Ive just got an armrest to fit to my S4. After reading previous threads I think I need a template to put over the center consol. So i dont have to remove it to cut the hole.
    Can anyone help?
    cheers ryan
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Simple mate, make your own cardboard template by drawing around the outline of the base (not the bracket), then from that template, go in an inch or two so to make a smaller template and use that one.
    The reason to use the smaller one is so there is room for the bracket to go through but the base of the armrest will cover the hole.
    If unsure of size, then always go small first as you can always cut the hole bigger, but you are screwed if you start the hole bigger.
    So no need to remove centre console mate.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,675
    Hi,
    I retro-fitted a centre armrest last year. You can read the story in this link. Ignoring all the nonsense about the wrong colour, I think post number 5 is where I described how I cut out the hole without a template. You definitely don't need to remove the console, but you will need unbolt it at the back end to fit the bracket underneath where the armrest will go. If I remember correctly, you need to remove the rear ashtray and a couple of trim bits.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Sep 2010
    Whitehaven, Cumbria
    59
    Perfect,
    Thanks for the help. Il let you know how it goes
    27,072
    Yeah no need for template tbh, just look at the base of the armrest, should be fairly simple overall, done loads before.
  1. Retrofit Armrest HELP
    By Taz1 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th November 2011, 20:07
  2. RETROFIT - ARMREST What parts are needed?
    By HSerce in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th November 2009, 20:21
  3. Retrofit Armrest Phone Prep
    By S4_marv in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th October 2009, 16:04
  4. Centre armrest, retrofit..
    By stevethejambo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st December 2005, 21:59
  5. Armrest - A4 Avant
    By A4Steve in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th February 2003, 18:51
