Chris NottJMB Retrofits
    Oct 2009
    N Wales / Cheshire borders
    10
    2.0T FSI Quattro Thermostat
    anyone had any issues with a failing thermostat and a reduction in performance - sluggish engine? Coughing?
    Molnboman's Avatar
    Just changed mine last month.....the car was running ok...but noticed it was sitting under the 90c quite a bit and using more fuel as a result. Can't remember how much it cos '( 45 quid? )t but it was an hours labour I think ....it's not easy to get at.
    Good Luck
    A
    Nov 2012
    Worcestershire
    89
    Mine has done 83k and cant see that it has been changed - however they are fairly common parts so cant hurt (mine sits bang on 90 whatever i do?!)
    Oct 2009
    10
    Mine sat bang on for years, then I've noticed it drop plus performance suffer and fuel usage increase.
    Took it to my mate tonight who plugged it in and gave fault codes for thermostat and diverter valve (or equivalent at least). Going to sort it this week. Will keep you updated!
    Molnboman's Avatar
    Yep, the diverter might throw up a underboost code but wouldnae think it would have affectd the water temp though....it didn't on mine. Sounds like they both have gone on yours Jamerson. I have replaced both btw separately this year. I think they had never been replaced before. You'll notice a difference with both changed am sure. Make sure it's genuine parts and the dv is the new improved version.
    Keep us posted.
    BR
    A
    chrisa4quat's Avatar
    Sep 2004
    897
    I replaced mine a few months back. Wasn't sitting on 90 degrees. More like 80-85. Reasonable job for me and one of the tech's. sorted my issue tho
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
  1. A4 2.0T FSI Quattro S-line common fault?
    By tmitch45 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 10th August 2007, 12:07
  2. Owners 2.0T FSI Quattro question
    By Steve-L in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd August 2007, 17:42
  3. Replies: 3
    Last Post: 19th May 2007, 15:52
  4. 2005 AUDI A3 2.0 T FSI Quattro S Line 3dr HELP
    By new wheels in forum General Chat
    Last Post: 18th May 2007, 23:15
  5. Anyone test driven the new 2.0T fsi quattro?
    By AndyMac in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th September 2004, 18:35
