Badger5Chris Nott
Results 1 to 9 of 9
    Euans2's Avatar
    Nov 2012
    Scotland
    37
    MPG DIS Question
    Hi
    My car currently has the miles to empty feature on the dash, is it at all possible to change this? My old Golf had the computer with all the options and the wiper stalk had the controls to change between the options.
    Is it be possible to activate the computer setting through VCDS and also would I be able to change the settings if I get the correct stalk?
    Apologies if this has already been asked, I done a quick search but couldn't find an answer
    Jan 2012
    1,837
    MPG DIS Question
    Enable it via vcds and change your wiper stalk for one with the computer controls
    Dec 2006
    N.Ireland
    369
    I just done this recently
    you need to buy and fit a stalk (about £35 second hand) i got a new one for about £80
    Whilst you have the bottom half of the dash removed you need to use a snap lock connector on the brown/red wire going into the back of the instrument cluster and ground this to the chassis to stop the empty washer warning light
    Then i copied this for the coding
    To enable Cruise Control and DIS, you need to do the following:
    1) Open VAG-COM (connected to your port and ignition in position II)
    2) Click on module '16 - Steering Wheel'
    3) Go into 'Recode (07)'
    4) The only bit in the code you need to change is the second last digit (i.e. 0xxNx - where N is the bit to change, x are your current values). If you do not currently have CC or DIS, this should be '0'.
    5) Make a note of the current coding!!
    6) Change N to '4' (i.e. 0xx4x)
    6) Click on 'Do it'.
    7) Go back to the main 'Select Control Module' screen.
    8) Click on the module '17 - Instruments'
    9) Go into 'Adaption - 10'
    10) Go to channel 19 and click on 'Read'
    11) Make a note of the 'Stored Value'.
    12) This may be a bit more of a tricky one, so if you are stuck, let me know the stored value and I'll tell you which code to enter. Basically, you'd need to have x12xx, where 'x' is your current value and 12 is the new coding. For help on what this means, try this site:
    RETRO FITTING DIS AND CRUISE ON A4 B6 - Page 2
    Euans2's Avatar
    Nov 2012
    Scotland
    37
    Excellent. Just the answer I was wanting to hear.
    Thanks guys.
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    826
    I find it odd that some cars did not come with that wiper stalk as standard kit, even the non-colour DIS has this functionality (change what it displays), so why not include the buttons as standard?
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,111
    Quote Originally Posted by Euans2 View Post
    Thanks guys.
    Hi Euan, I have a used one if interested, it is like new. £37 posted mate, let me know.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,703
    Quote Originally Posted by jjmurphy21187 View Post
    That's Audi for you.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Euans2's Avatar
    Nov 2012
    Scotland
    37
    Quote Originally Posted by Dannykn9 View Post
    Hi Danny, I think your PM box is full.
    Thanks for the offer, unfortunately I have already managed to get hold of a stalk.
    Thanks again for the offer though.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,111
    Cleared my inbox now.
    Ok mate, no worries.
  1. A8 - D3 MMI/DIS Question
    By dragondownsouth in forum A8/S8 forum
    Last Post: 2nd November 2010, 20:00
  2. Average MPG - DIS playing games???
    By Maz in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th November 2008, 10:48
  3. DIS question
    By L60N in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th May 2008, 18:40
  4. Quick DIS question
    By cdb2 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th April 2005, 17:29
  5. AMD Stage 1 and DIS questions
    By imported_AndyB40 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th January 2005, 12:14
