JMB RetrofitsChris Nott
    Boulders's Avatar
    Sep 2009
    Cambridge
    19
    Disc size for 2.0 TFSI
    I promise I've used the search but I'm still none the wiser! The brake pad warning light has come on and it's time for some new pads. Coming up to Christmas I'd like to save some cash and am reasonably handy with a spanner. Can anyone confirm the disc size on my car? It's a standard 2.0 TFSI S-Line FWD.
    I've heard good things about Mintex pads from MTEC. Are these the correct ones? MDB2231 Mintex Brake Pads
    Many thanks
    Simon.
    John@mk's Avatar
    Feb 2012
    Milton Keynes
    105
    Hi Simon,
    Mines the Quattro version which are 312mm discs, but check the option codes in the front of your service book, one of those should relate to disc size.
    hopefully someone might know the code you are looking for,
    Good luck.
    2.0 T Avant quattro s-line.2005
    chrisa4quat's Avatar
    Sep 2004
    897
    Mine are 321mm. Is it a special edition? If you message me the reg ill find out of vehicle details
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    John@mk's Avatar
    Feb 2012
    Milton Keynes
    105
    VW Group Option Codes Decoder
    This is the link to explain the optain codes...
    Sorry mine are 321mm,
    Boulders's Avatar
    Sep 2009
    Cambridge
    19
    Thanks for your help guys. Chris you have a Pm and John thanks for the link!
    Sep 2004
    897
    Pm replied :-)
  1. Front brake disc size for 2006 A3 2.0TDI 140 FWD manual?
    By Mikey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th September 2011, 18:50
  2. RS6 replicas - best size for A6?
    By Birchamj in forum Handling
    Last Post: 16th January 2005, 16:35
  3. Bolt size for the hub on a 1999 A4 Quattro Turbo
    By swsimon in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th June 2004, 18:56
  4. whats biggest wheel size for stock A4 SE (1998)
    By manikm in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th May 2004, 13:17
  5. max wheel size for wheel well?
    By sash in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th February 2004, 18:09
