Chris NottSky Insurance
Results 1 to 10 of 10
    ctd
    Oct 2012
    Plymouth
    105
    Rear Washer leak
    I have a 55 plate avant and when I use the rear windscreen washer I get water pouring out of the tailgate. The pipe had come apart under the near side front wheel arch but when I fixed that I noticed the water in the boot, how do I remove the tailgate liner to get at the pipe
    cheers guys for any help
    Jan 2012
    KERNOW
    107
    There are 4 screws on the tail gate trim, 1 in each of the handles and 2 behind the warning triangle. Then you have got to pull the cover down which is held on by clips that can be a pain in the ass!
    Are you sure that the leak is coming from the tailgate and not from inside the rubber by the hinge that the pipe runs through.
    ctd
    Oct 2012
    Plymouth
    105
    no sure the water in coming out from the trim just below the window but it could be running from above, how do i get the trim off from round the hinge, it looks like plastic not rubber
    Jan 2012
    KERNOW
    107
    there is plastic that you've got to take off to get to the rubber gaitor which you just pull off if i remember correctly.
    Mine was leaking there about a month ago and i found it by opening the tailgate, holding it so it was in line with the roof (half open) and getting someone to work the washer while i watched and noticed it leaking from the plastic trim around the window
    ctd
    Oct 2012
    Plymouth
    105
    the trouble is all the fastners are hidden, i want to strip the trim off the tail gate to fit a rear view camera at some time so would like to know how the trim comes off
    Jan 2012
    KERNOW
    107
    As i said earlier 4 screws and then pull the trim off, if you are going to put a rear view camera on you may need to pull the top trim off which is just clipped in.
    Good luck finding the water leak and fitting the camera, let us know how you get on!
    Jun 2010
    South Wales
    69
    You'll be surprised by how much pressure you'll need to pull it off. I found it a right bast@@d to put back on the. Clips inside we're a pain to line up.
    ctd
    Oct 2012
    Plymouth
    105
    all done now, pipe had split in two inside the ruber sleeve at the hinge, went down to my local pet shop and got an aquarium air pipe joining part and glued it in line, bit of a bugger getting it all back together but all working now, while i was in there i ran a feed for the reversing camera through the door and left it coiled above the headlining ready to run down to the reverse light, that'll be another day
    Jan 2012
    KERNOW
    107
    Yeah that was where mine had gone and may others i believe. The plastic pipe that they use is s**t, too rigged for the hinge so i did what you did and put a "proper" bit of flexible pipe in.
    ctd
    Oct 2012
    Plymouth
    105
    no just a temp fix for now, glued one of these into the split pipe
    Aquarium Fish Tank Air Tubing Straight " I " Shape Connector New free Postage | eBay
    working fine for now, don't know how long it will last
  1. Rear washer leaking into boot on offside.
    By garethk-d in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th May 2012, 10:53
  2. rear wiper washer leak causing bose amp problem on avant
    By alfie155 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st August 2011, 00:47
  3. Rear washer leaking, front near side...
    By SixDegrees in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th October 2009, 00:09
  4. Rear washer leaking at front of car
    By Syzygy in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2006, 09:54
  5. S3 rear washer jet problem
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2004, 15:34
