Volks AutosJMB Retrofits
Thread: PCV Test
    Oct 2012
    79
    PCV Test
    As some my know I am trying to track down a light missifre at approx 2,000rpm.
    I have just read about the PCV being a common failure and that a sympton is breather air being sucked into the intake in during vacum, which is where it would be during light throttle/2,000rpm
    A test for this seems to be attempting to remove the oil filler cap to see if it runs rough or has suction.
    When I initially viewed the car I took the oil filler cap off to check for contaminants/head gasket failure while it was running and the car imediately stalled.
    Would this indicate a PCV issue ?
    Jun 2009
    186
    Symptoms to check, oil around filler and coil packs. Take inlet manifold pipe off on manifold side and blow through it, if its blocked thats good if air flows freely its knackered. If theres vacuum at the oil filler while motors running thats fine. Lift dipstick halfway, if theres a suction sound coming from the "puck" of the PCV its fine.
    This is in my experience, I just replaced mine for no reason before discovering all this! Doh!
    Pabs's Avatar
    Jun 2010
    Manchester
    617
    Had the same problem on my b6 1.8t 190, check the crankcase breather valve they are known to go and only cost a few ££££, the symptoms are rough idle ( sounds like a subaru, bob bob bob bob bob), stalling when you take filler cap off, changed mine and it cured the rough idle straight away and now purrs like it should do...
    A4 1.8T 190 S-Line, Stage 2 Shark Performance Map 230 BHP, Pipercross Panel Filter, Forge 007 DV, Blue Flame Performance Exhaust + High Flow Sports Cat, 8k HID Lights, 8k HID Fog Lights, LED Sidelights, LED Number Plate, Front + Rear Ambient Lighting, LED Interior Bulbs, Grooved Dimpled Disks, Ultimax Pads, RNS-E DVD, Tinted Windows, S4 Grill, Votex Rear Skirt, BOSE, Leather, Engine Covers, S4 Mirrors, RS4 Pedals, Gloss Black Wrapped Grills, 19" BBS LM's Summer, 19" RS6's Winter, Coilovers
  1. Top Gear road test PDF files for S3?
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th July 2003, 12:13
  2. Test Drove New A3
    By dbm in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2003, 23:21
  3. TTC180 road test results anyone?
    By Mikiew in forum TT/TT-S/TT-RS Forum
    Last Post: 22nd June 2003, 20:51
  4. Tested ... 220km/h for A3 2.0 TDi
    By roberto in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th June 2003, 04:58
