JMB RetrofitsBadger5
Results 1 to 7 of 7
    gas-man's Avatar
    Jun 2012
    207
    mfsw advice please
    hi everyone
    doing a deal on a3 spoke mfsw steering wheel with airbag from a 09 a3 to fit on my 2005 avant which as a 4 spoke mfsw
    will this work and if yes will it need coding
    many thanks in advance
    ps did do a quick search but the deal is to go ahead in a little while so just trying to make sure
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,609
    mfsw advice please
    It will work but it will need coding and will also need a Highline Steering ECU, which you probably wont have.
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,534
    Quote Originally Posted by jb0o View Post
    Is that true? - since gas-man says he already has an MFSW (a 4-spoke one) won't his SCSM already work with the A3 MFSW?
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    gas-man's Avatar
    Jun 2012
    207
    thanks for your replies guys
    really hopeing this is just an easy straight swap out
    so if anyone can give me the answer i dont want to be
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    2005 is it a B6 or B7 you have, B6 use single stage airbag wheels with buttons. The A3 will be a dual stage airbag. That may be your first issue.
    If you have a B7, then I don't see any problems except making up the correct airbag loom.
    gas-man's Avatar
    Jun 2012
    207
    Quote Originally Posted by s8craig View Post
    thanks graig it is a b7 not sure i understand about the loom?
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Straight swap no coding needed as you already have a MFSW.
    Only issue may be the airbag loom connector to the slip ring as it may be slightly different to that of the A3. You can always test first and if does not fit, then swap the loom from your 4 spoke airbag.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
  1. S3 advice please
    By V5Ade in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th September 2004, 22:13
  2. S4 Advice Please
    By azzurro2222 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th June 2004, 20:12
  3. advice please
    By stv in forum A8/S8 forum
    Last Post: 10th June 2004, 13:25
  4. Ess Three advice please...
    By wizard in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2004, 21:45
  5. Considering buying an S3 - Advice please!
    By Rich1275cc in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th December 2003, 08:47
