AH FabricationsSky Insurance
Results 1 to 18 of 18
    May 2010
    Glasgow
    31
    Bumpy / Rough Idle
    hey - recently I noticed a bumpy idle which i didn't really take any notice of but over the past few weeks it's got a fair bit worse. I've got 72k on the clock so i'm due a service in around 5k miles. On a cold start it takes a couple of seconds to startup and then the rough idle begins. Usually first thing in the morning and when i've finished work. I noticed it got worse after a round trip towards Manchester which clocked up around 400 miles but i'm by no means a rough driver - especially on long journeys.
    Any ideas ??
    dubdemand's Avatar
    VAG Addict
    Aug 2010
    Surrey
    405
    170bhp Tdi? If so that's the least of your problems...
    Our does it and I've given up trying to find a fix
    2009 A4 2.0 TDI (170) Avant S Line Exec. ​Quartz Grey, S Line suspension, Bluetooth phone prep low, AMI, DAB, Symphony III, Leather/Alcantara, rear sun blinds, heated/dimming/folding mirrors and cruise control. Mods so far: BBS LM (reps), needle sweep and dipping mirror on reverse. To come: spacers, rear window tint and badge delete.
    ctd
    Oct 2012
    Plymouth
    105
    egr valve?
    May 2010
    Glasgow
    31
    Quote Originally Posted by dubdemand View Post
    Did you also try EGR Valve? Did you get it scanned for fault codes pal?
    Quote Originally Posted by ctd View Post
    egr valve?
    Would a VAG scan bring up error codes if there's not Engine management light displaying?
    ctd
    Oct 2012
    Plymouth
    105
    no didn't show up on diag, just had mine cleaned and the rough tick over and slight hesitation around 1800revs(not all the time) seems to have gone
    May 2010
    Glasgow
    31
    jeezo that sounds exactly like mine, I felt a slight bump at just under 2,000 revs this morning. Did you clean it yourself?
    ctd
    Oct 2012
    Plymouth
    105
    No local performance garage did it for 1hrs labour/£62.50, not worth getting hands dirty for that much
    dubdemand's Avatar
    VAG Addict
    Aug 2010
    Surrey
    405
    Our EGR valve looks brand new from outside and is much cleaner than the rest of the engine. I have asked my mechanic to clean it when it's been in for work in the past so assume he has done it. We still have lumpy idle and hesitation in the rev range... We also have the dreaded limp mode and no clear solution.
    Onlyfault code gives us low bost pressure and apparently there is a long list of possible components. Mechanic has suggested working through it starting with the cheapest first. Fecking car!
    Mar 2011
    North Wales
    201
    Clean the EGR valve, take the inlet manifold off and clean all the crud from the flaps and while it's off change the vacuum actuator ( only about £10 ) as the diaphragms split inside. Did mine and it runs much better, no more hesitation or rough idling. Quite an easy job.
    May 2010
    Glasgow
    31
    Re: Bumpy / Rough Idle
    Will probably give this a bash this weekend and will report back my findings, cheers for the replies so far.
    Mar 2011
    North Wales
    201
    If you are replacing the vac unit the main dealer may not find the part number.
    It is S03G129061C
    You'll also probably need egr gasgets and inlet manifold gasgets ( less than £10 for all 3 )
    Oh and about 2 - 3 cans of carb cleaner aerosols
    May 2010
    Glasgow
    31
    Quote Originally Posted by mm707 View Post
    It is S03G129061C
    thanks mate - should I be touching the anti shudder unit?
    Are you using ETKA by the way?
    Oct 2012
    57
    I did a service on mine and new air filter improved the judder. But this is defo on my list of jobs. Once the wifes A3 is back on the road. Does it improve economy at all if so it will go higher up the list
    Mar 2011
    North Wales
    201
    Quote Originally Posted by 5aq1b View Post
    I got my parts from TPS , the part numbers are from their invoice, pretty sure they are ETKA - prefer to use them than main dealer.
    you need to unbolt the anti shudder unit but don't do anything with it.
    One thing to watch out for, which caught me out, is that one of the inlet manifold bolts is in the air intake and probably covered in muck so not easy to see at first.
    gasget part numbers are
    03G131547F
    069131547D
    03G129717D
    There is a good thread on here somewhere about removing the EGR, I just followed that and the inlet manifold is easy.
    The vac unit will only go on once the manifold is off and it's fairly obvious to see how it fits.
    May 2010
    Glasgow
    31
    03G131547F
    069131547D
    03G129717D
    thanks mate - what tools do i need to take these off?
    Mar 2011
    North Wales
    201
    You need some torx bits, not sure what size, if you have a look at your inlet manifold you will see some bolts to give you an idea..
    Have a look at this thread .......
    Another 2.0TDI EGR Valve Cleaning Thread - with before and after pics.
    Oct 2012
    57
    HMM Has he cleaned the inside. Or just done the scratches head whats he asking me that for and cleans the outside anyway. ..
    Mar 2011
    North Wales
    201
    What is the error code number ?
  1. Rough Idle
    By 1mran in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2007, 22:37
  2. Rough Idle
    By melman in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2007, 19:29
  3. Rough Idle now to tranny prob A4 2.8
    By ad3crk in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th October 2006, 18:35
  4. Rough Idle
    Last Post: 8th October 2006, 09:52
  5. Rough idle after cambelt change
    By in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th June 2005, 18:19
