Sky InsuranceBadger5
Thread: ESP light
    Oct 2011
    Cumbria
    89
    ESP light
    Hi guys, just wondering if anyone could maybe shed any light on my current predicament.
    The esp light has started to come on whilst driving my tdi, it seems to come on and stay on whilst driving but goes away again when the ignition is switched off. There's no obvious pattern to when it comes on and it doesn't bring any other lights with it ie. no abs light etc.
    Now my first thoughts are the brake sensor, however with the lack of abs light and still fully functioning brake lights I'm doubting that to be the cause.
    One possibility that springs to mind is that I currently have uneven tyres on the front. Could this be screwing with the diff? Is there a sensor in there to be confused?
    Only other possibility is that I did a cleanout out of the egr valve a few months back, could something in that process maybe have caused an issue?
    I'm currently arranging for a vagcom scan but wondered if in the mean time somebody may be able to shed some light on the situation
    Any help greatly appreciated.
    A4 Avant tdi S-line
    May 2011
    195
    This may sound really dumb buddy but have you tried pressing the button for the ESP?????
    Dec 2012
    Hi mine a4 has just stared to do the same. yes have pressed the button.
    Jun 2010
    South Wales
    69
    How bad are your tyres. Do you mean uneven tyre wear or one tyre has more tread than the other.
    V.A.G.erbond's Avatar
    Spooling
    Nov 2012
    Leeds
    131
    Hi mine did that not long after I bought it traced it to faulty MAF and engine breather valve. replaced them (paid for by the dealer) problem gone. My mate with VagComsaid it because the ECU isn't getting a proper reading or something like that. Anyway a month later still no issue.
  1. ESP Light on Dash............
    By GarryX in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st December 2005, 16:40
  2. Have you ever seen your ESP light??
    By marctwo in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st October 2005, 22:39
  3. ESP light comes on in high boost?
    By s3withproblems in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2005, 00:12
  4. Engine management light and ESP light on
    By AndyS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th June 2005, 14:30
  5. ESP light: HELP!
    By t30gue in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd July 2004, 10:09
