Monster MotorsportChris Nott
Results 1 to 7 of 7
    May 2011
    17
    A4 2.0TDI 140 Loads Of White Smoke
    Hi all, the A4 has started to smoke like its got 200 bensons on the go at once. Does not seem to loose any power and is fine driving but when it pulls up at lights etc its smoking like crazy, white blue smoke not dirty black and smells a a bit oily. Strange thing is it doesnt do it all the time, most of the time its fine with little or no smoke?..EGR valve sticking perhaps, what do you think?
    Audi A4 2.0 TDI Convertible (B7) in Phantom Black
    Nov 2011
    Sheffield
    31
    I seem to have the same issues and it's only visible when the temperature starts to drop. Will be keeping a close eye on this thread and I'll try to upload a video later.
    Jun 2009
    186
    EGR is usually black smoke.
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    the living room
    3,594
    i would say turbo oil seals on the last legs!
    Sep 2007
    Chester
    46
    Whats your coolant levels like? Mine did the same, turned out the head was cracked!!
    Jun 2009
    186
    If its only when its cold and engines cold thats just steam, if all the time white smoke sounds like head gasket or head (smoke may have a sweet smell to it, like antifreeze). White blue is usually rings or turbo seal.
    Mar 2011
    112
    If it smells of unburnt fuel and as you say it is whitish blue in colour it could be a sign of retarded injection timing and is sometimes referred to as a slight cool misfire. Could be a sensor giving incorrect reading and timing is retarding to quickly before engine is at correct temperature.
  1. A4 2.0TDI 140 Smoking
    By janzbro in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 23rd October 2012, 14:12
  2. '00 2.5tdi clouds of white smoke!!!
    By 0v0 in forum Diesel forum
    Last Post: 18th May 2011, 00:34
  3. Lots of white smoke when starting my A3 2.0TDi 54plate..
    By sarah1989 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th March 2010, 11:29
  4. White Smoke?
    By vishal in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2006, 13:45
  5. white smoke???
    By ImportRacer in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th May 2004, 02:35
