AH FabricationsEM Tuning
Results 1 to 8 of 8
    Aug 2012
    19
    Heater/aircon stinks
    Hi there
    as title my heater/aircon stinks of pi55 which dissappears after a short while but recently I've had an intermittent smell of a burning toxic plastic smell coming through the vents when the heater is on. Is there a definitive solution to this and should I be worried?
    Cheers........RAW Audi.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,467
    Maybe it needs regassed. x
    Greeny233's Avatar
    Mar 2011
    Llangollen
    688
    Follow Greeny233 On Twitter Add Greeny233 on Facebook Add Greeny233 on Google+ Visit Greeny233's Youtube Channel Visit Greeny233's Instagram Channel
    It is bacteria building up in the vents and aircon system. You can get air-conditioning antibacterial spray from eBay or an air-conditioning specialist. Just spray it into the air inlet (where the cabin filter is).
    A little trick I do occasionally is to spray the cabin filter with febreze which makes the aircon smell nice.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
    scotty76's Avatar
    Nov 2011
    Berkshire
    1,077
    You can also get them in Halfords if you don't want to wait for the post.
    Halfords | Comma Aircon Cleaner
    Feb 2011
    Leicester, United Kingdom, United Kingdom
    359
    Also change the cabin filter
    Jun 2009
    186
    Good luck mate, had this with my B6, no amount of cans of very expensive air con treatment worked. Try running it hot for a while to kill the bacteria, I never found anything to cure it and just had to open the windows for a minute while the initial stink went away.
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    just about, right here!
    3,755
    stop turning it off! and it will fix itself!
    leave it on all of the time! run it very hot for about half an hour, to get rid of the stale bacteria and then just leave it on all the time you use the car! adjusting the temp to suit! normally about 20" in my car!
    mine did the same because i was told it costs fuel to run it, and then it started smelling! i left it on and it fixed itself in about 3 days!
    these are not meant to be turned off but constantly on to adjust the cabin temp.
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    2,003
    I leave mine on all the time, never really noticed much difference with fuel economy when it was turned off so its left on.
    Cuts out the smelly outside world
    JSD 2.59
    Synergy-Solutions
  1. Heater/Aircon noise
    By MrTackalakalaka in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th April 2012, 09:53
  2. C5 A6 Aircon/Heater Synchronization
    By HerefordQuattro in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 9th February 2011, 23:12
  3. heater control valve
    By humlicek in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th November 2003, 02:36
  4. Heater problems
    Last Post: 24th October 2003, 13:33
  5. heater air flow Audi 80
    By Shane in forum Classic Audi Forum
    Last Post: 3rd August 2003, 22:05
