Volks AutosBadger5
Results 1 to 23 of 23
    May 2011
    195
    Help needed ASAP
    Hi guys. Basically my misses was driving to work when she noticed the engine management light come on. She stated that all of a sudden the the battery came on and the car lost power and stalled. I've been to the car and it turns over but won't start. I did notice that the brake light was flashing for some reason when I was trying to start it. It doesn't appear to be a snapped belt as it turns over at normal speed.
    I did notice the other day the lights in and out of the car were flickering.
    Anu suggestions until I can get access to vagcom. Currently waiting for the car to be recovered.
    Kind regrads
    lee
    May 2011
    195
    Oh also noticed that when then there is no key in the ignition the engine fan is spinning for some reason
    May 2011
    195
    Girlfriend just rang. She said she put the radio on now the cars completely dead and won't start over
    Jun 2009
    North Cornwall
    171
    Sounds electrical. Battery/Alternator most likely.
    May 2011
    195
    Apparently there was water in the black casing in the engine bay where there are 3 relays. Garage is going to dry them out. They said that this is a common problem on Audi/Seat etc.
    anyone heard of this before
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    yes the seal goes
    and the ecu and relays get wet
    quite common.
    May 2011
    195
    Bez, would drying them out and reseal the unit solve problem
    bez101's Avatar
    Jul 2008
    8,491
    Quote Originally Posted by fossie View Post
    yes it can work
    but it may have ****ed a relay or 2
    May 2011
    195
    Any ideas how much the relays cost Bez?
    lee
    chrisa4quat's Avatar
    Sep 2004
    897
    Help needed ASAP
    Normally down to drain holes blocking etc
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    May 2011
    195
    Ok so the garage have rang and said they have dried the relays out and the car still won't start. They said they have also tried 'hard wiring' the fuel pump but again it still won't start.
    Any suggestions. The garage said they are trying an auto electrician but may not be able to get one till Friday.
    Any help/advice would be great
    bez101's Avatar
    Jul 2008
    8,491
    have they scanned it
    any codes ?
    May 2011
    195
    They said they haven't scanned it. I might go down with my vagcom and plug it in. Ill give them an hour or so
    bez101's Avatar
    Jul 2008
    8,491
    Good garage then ?
    scan it post codes lets see if we can help your garage
    a auto sparkie aint gona be cheap
    and could still be a relay or a fuse etc from the water.
    May 2011
    195
    Just been down. Transpires that the car would start with the fuel pump hard wired however ran like a bag of ****e. Plugged into vagcom and showed glow plug control module.
    I beleive this means the relays are fooked??
    May 2011
    195
    Anyone, Bez?
    bez101's Avatar
    Jul 2008
    8,491
    Hmm what i would do is
    get the relays and swap them over
    is the ECU wet (if its in same box as the relays) ?
    my pals just had the glow plug module fault on his passat the car still ran im sure the part was around £60/70.
    i cant see the above module stoping the car from starting tho.
    Jun 2009
    186
    Surely it would stop it though if none of the glow plugs are getting hot?
    bez101's Avatar
    Jul 2008
    8,491
    yes you would think so
    but you have it started with the pump wired direct
    so i would be changeing the relays and looking what else is in the box with the relays.
    May 2011
    195
    Bez, in the box there are 3 relays (fuel pump, fan and glow plug), the other fuse(s) that were in there were fine. The expensive relay, think its the glow plug one was corroded so looks like it was like this for some time.
    What we did was clear the codes and start the car, it ran but really poorly. Scanned it on VCDS again and it brought up the glow plug fault. Again cleared it and started ot again and the same fault showed.
    I think we are just replacing the relays and taking it from there
    bez101's Avatar
    Jul 2008
    8,491
    yep i know there £££ from audi
    where are you located
    i have a few relays in the yard.
    May 2011
    195
    Im from County Durham matey, dont worry about the relays as the garage have ordered them. Im hoping i can argue that this is a warranty job
    bez101's Avatar
    Jul 2008
    8,491
    yeah bit to far down to get them to you
    anyway hope the relay sorts it
    get them fo fit the new rubber seal aswell
  1. Brake upgrade help needed ASAP!
    By PTTM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd July 2010, 16:40
  2. HELP NEEDED ASAP!!!
    By supanova in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st May 2010, 11:24
  3. Adapter help needed ASAP PLEASE
    By ruairi83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th May 2010, 00:40
  4. 1.9tdi(110) not revving, help needed ASAP
    By Lex in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd March 2009, 21:21
  5. Exhaust/Engine Question Help Needed ASAP
    Last Post: 21st January 2009, 17:36
