Hi everyone,
I'm pulling my hair out with this one, I've changed the clutch in my 2005 3.0TDI B7, had the flywheel off to inspect and put it back, as far as i can tell in the correct position.
Anyway i go to start the car for the first time and the starter motor just spins and appears not to engage. Fine strip out, bench test and the drive cog moves in and out as it should and runs up... Take to a auto electrician and he checks it and replaces the drive clutch as says it could be the prob.
Back in the car and guess what, still just spins at what appears to be full speed. I've checked the earth connection to the engine and from the starter housing to the coil just to make sure, all seems fine and resistance is good too.
Has anyone got anything to suggest as to where i go next with this, as i'm really not looking forward to having to drop the gearbox back out to check the flywheel is all ok? I should add that i can get the teeth on the flywheel to turn and aren't sheared off etc.
