Sky InsuranceAH Fabrications
Results 1 to 30 of 30
Like Tree1Likes
  • 1 Post By bez101
Thread: Emission Control warning Light, erratic idle speed = my car doesn't like motorways!
    Jun 2011
    Manchester
    248
    I keep getting a problem whenever my car has been on a Motorway/dual carriageway run.
    I recently went from Manchester to Glasgow for the weekend and upon returning back to Manchester the Emission Control Warning light came on when I exited the Motorway after approx 4 hours driving.
    The light stayed on for 2 days and then went off. This was 2 weeks ago.
    The light has now come back on and been on for approx 48 hours and I haven't done any long driving runs.
    The other problem I have is erratic idle speed again every time I go on a motorway run, even if its just for a couple of miles.
    When I exit the motorway and come to a stop, the idle speed varies between 1000 and as much as 1400 rpm sometimes, it sounds like my car is revving its tits off!
    The only way I can bring it down is to gently let the clutch out a bit, but as soon as I depress the clutch again the idle speed begins to creep up. Its so annoying that I now hate it every time I use a Motorway or similar type of road.
    I have had the Coil pack recall done plus recent Cambelt & water pump change, but the erratic idle speed was present before these were done anyway.
    Anyone have any ideas what the problems could be? Could they be linked?
    Thanks, Dan.
    2005 B7 A4 2.0T in Moro Blue
    Interior, Number Plate & Sidelight LED's from T8ups, 18" 9 Spoke TT Wheels.
    BGB Engine Code.
    Jun 2011
    Manchester
    248
    Emission Control Light now gone off again!
    Could the ECU be temperamental/faulty and does anyone know approx cost to replace the ECU?
    BGB Engine Code.
    solaris's Avatar
    Slough, Berkshire
    404
    Could be the PCV valve, a scan would confirm this..more info here
    If it's not longitudinal and it's not Quattro..it's not an Audi
    VCDS (VAG-COM) HEX-CAN USB cable carrying member
    2005 A4 DTM 2.0 TFSi Quattro :364Bhp/477NM - Mapped by MRC Tuning
    Hybrid K04 Project ongoing (link to Build thread)
    DMFW + Clutch For Sale
    Jun 2011
    Manchester
    248
    Quote Originally Posted by solaris View Post
    Thanks Solaris, this sounds just like my problem as I have noticed MPG has gone worse too.
    Can you remember the price of the PCV Valve and is that the Audi Part Number (part number 06F129101N)?
    Cheers, Dan.
    BGB Engine Code.
    olethalb's Avatar
    Aug 2012
    314
    mine does the same ocasionally, just fitted BSH PCV fix plate but still does it. seems to be an issue with a split pipe to my carbon cannister.
    As Solaris says though PCV is first port of call
    Jun 2011
    Manchester
    248
    Any idea on approx cost of PCV Valve and Gasket?
    BGB Engine Code.
    olethalb's Avatar
    Aug 2012
    314
    i bought a plate that gets rid of the PCV part completely, turns out my PCV was fine anyway (recently replaced) by precvious owner.
    sorry can't say how much a new PCV is
    Jun 2011
    Manchester
    248
    How much was the plate you bought then olethalb?
    BGB Engine Code.
    olethalb's Avatar
    Aug 2012
    314
    can get them for £80 for the kit, got mine off ebay used but cheap
    quick google gives US result but you get the idea
    BSH 2.0T FSI PCV Revamp - BSH Speedshop
    Jun 2011
    Manchester
    248
    OK, PCV and gasket successfully changed last Friday. Took me about 15 mins once I got the correct tools!
    Part Numbers & prices were as follows: PCV at £37 = 06F 129 101N and Gasket at £18.40 = 06F 103 483E
    BUT, still got the erratic idle issues and the Emission Control Warning light has come on again
    Is it time to get someone with VCDS to plug it in??
    BGB Engine Code.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,429
    i cant belive ppl still change parts when hey havent had a scan for codes
    its a waste of time and money
    it could be a split pipe or even the MAF
    unplug the maf see how it runs.
    Jun 2011
    Manchester
    248
    I did think that bez but read somewhere that changing the PCV valve after 50k miles was a good idea anyway, but lesson learned!
    Where abouts is the MAF?
    (By the way, was it you I came to in Sheffield to clear my airbag light when I changed the wiring under the seat?)
    BGB Engine Code.
    bez101's Avatar
    Jul 2008
    8,429
    Quote Originally Posted by mancdan View Post
    iv done a few infact loads
    so yeah could have been
    across from the pub an carwash ?
    Jun 2011
    Manchester
    248
    I think so, on the main road with tram lines?
    Rough idea as to where the MAF is so I can unplug??
    BGB Engine Code.
    bez101's Avatar
    Jul 2008
    8,429
    yeah thats me
    the maf is on the left as your looking under the bonnet on the pipe going to the airbox
    put a pic up ill point it out.
    Jun 2011
    Manchester
    248
    Here you go Bez, hope picture is close enough.
    BGB Engine Code.
    bez101's Avatar
    Jul 2008
    8,429
    remove the big airpipe
    and you will se eit under there
    Jun 2011
    Manchester
    248
    Should the MAF just unclip and pull out or do I need to remove those security torx screws?
    BGB Engine Code.
    Jun 2011
    Manchester
    248
    Unplugged what I thought was the MAF (part no. 06F 906 461A) and ESP light has come on!
    Have I unplugged wrong part?
    BGB Engine Code.
    bez101's Avatar
    Jul 2008
    8,429
    the MAF may send a light on
    there is 2 security screws holding it to the tube
    when u get a new maf its already in that tube
    to clean it u need to remove them i have a use 1 with around 1k miles on it
    take a pic with thebig air pipe off ill point it out
    Jun 2011
    Manchester
    248
    I didn't need to remove air pipe to unplug the MAF so will need to remove it and then take a pic for you.
    Let me know how much you want for your used one too.
    Cheers.
    BGB Engine Code.
    bez101's Avatar
    Jul 2008
    8,429
    (it was the MAF you unplugged)
    how did it drive when you unplugged it
    Highlander1969 likes this.
    Jun 2011
    Manchester
    248
    Haven't drove it yet but am about to leave work so will know in the next few mins and report back later!
    BGB Engine Code.
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    940
    Mine idles too fast when cold so changed pcv anyway its done 88,000 so probably past its best,i would like to give the valves a clean next and change fuel pump follower at the same time.
    06 A4 AVANT QUATTRO 2.0T S-LINE SE,GARNET RED, RS4 REAR ARB,SPACERS ALLROUND,H & R SPRINGS,B5 PERCHES,A6 V8 RIMS.PORSCHE CAYENNE TURBO S SIX POTS .REVO ST2 MAP ,MILLTEK CATBACK EXHAUST,PANEL FILTER,034 INTAKE PIPE.
    Jun 2011
    Manchester
    248
    Well, unplugging MAF didn't alter the erratic idle as it appeared again this morning whilst in traffic and I had only driven on A/B roads, max speed 35mph and done approx 6 miles. Also the Emission Control warning light came on again.
    I have now plugged the MAF back in again and ESP light has gone out but ECW light has stayed on.
    This is a video of the erratic idle whilst at some traffic lights this morning. You can see that I revved it a little at 8 seconds to see if it would go back to normal and it didn't.
    I also let the clutch out a bit at 22 & 46 seconds to get the idle down, but as soon as I depress the clutch back in, the idle speed goes back up again.
    Its driving me fckin mad now and I'm thinking it really needs to go on VCDS.
    http://s6.beta.photobucket.com/user/...cIdle.mp4.html
    Last edited by mancdan; 26th October 2012 at 09:55. Reason: video link not working
    BGB Engine Code.
    bez101's Avatar
    Jul 2008
    8,429
    if your around my way again ill scan it you
    see if the problem is stored
  28. #27
    Jun 2011
    Manchester
    248
    Cheers Bez, I'm never usually around Sheffield but would make a special trip there just to get it scanned as its really bugging me!
    When is a good time/day for you?
    BGB Engine Code.
  29. #28
    bez101's Avatar
    Jul 2008
    8,429
    sunday after 5pm
    or day next week after 7pm
  30. #29
    Jun 2011
    Manchester
    248
    Cheers mate, I will let you know.
    BGB Engine Code.
  31. #30
    Jun 2011
    Manchester
    248
    This issue has now been fixed by Rick & Spencer at Unicorn Motor Developments in Stockport.
    It turned out to be the N80 Valve and so far the idle speed is perfect and car runs a lot better too.
    Cost of new part approx £25 plus an hours labour to fit.
    I would like to give a big shout out to both these guys as they are very thorough and have a great wealth of knowledge.
    I would have no hesitation in recommending their services.
    Now to save some pennies for one of Rick's customer remaps!
    BGB Engine Code.
  1. Help please! - emission control warning light
    By gambit in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th December 2009, 17:57
  2. flashing emission control system light on S3
    By julians in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st February 2009, 13:48
  3. Emission Control System Light
    By jumpers in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2008, 21:08
  4. Emission Control System light's on.
    By dkelly in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th July 2007, 10:02
  5. Do i Have an Engine Management Light? Erratic Idling?
    By H17E5H in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th April 2007, 16:27
