AH FabricationsChris Nott
Results 1 to 20 of 20
    V6 Quatt's Avatar
    Feb 2008
    742
    Multifunction Steering Wheel with paddles
    Another steering wheel question.
    I already have a multifunction wheel on my 3.0 TDI A4 B7 but wanted to upgrade with the flappy paddles for my tiptronic.
    I have seen one on ebay with multifunction, shift paddles and complete with Air bag off an Audi S5
    Will it be a straight swap?? and would it possible to get the progammed paddles to work??
    Help needed as I dont want to purchase in error.
    If anybody can recommend me to someone who knows about this mod?? would be appriciated.
    Torque the Torque
    26,722
    Depends on the year of the wheel, any pics?
    V6 Quatt's Avatar
    Feb 2008
    742
    The wheel is 2009 S5 with air bag help needed
    Torque the Torque
    26,722
    Again, post pic of the wheel so we're sure of the type incase its been labelled wrong.
    V6 Quatt's Avatar
    Feb 2008
    742
    Torque the Torque
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,074
    Yep, should be straight swap, with one bit of coding in VCDS. Go to module 16 and code for tiptronic.
    I done the same mod for another guy not too long ago.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    26,722
    The airbag loom on the S5 wheel may need adapting or you may have to use your existing partially, you'd have to check this upon purchase.
    Apr 2012
    N. Wales, LL22
    1,224
    that s5 wheel looks just like the one on my a6 s line, i guess its worth more if its advertised as an S5 one
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    26,722
    Its a little chunkier, is nicer to drive with tbh as same as rs6 diameter.
    Apr 2012
    N. Wales, LL22
    1,224
    oooh i'll have to look at upgrading what wheel does the s6 come with?
    VCDS in North Wales
    26,722
    Standard is round afaik, RS6 wheel is great, just sold new one, but have another coming, not cheap thats for sure.
    Feb 2008
    107
    Are you sure that S5 wheel pictured is same rim width as an RS wheel - I suspect it's same as the S4 wheel (not flat bottom variant), which is slimmer than RS - and the same as the S-lines.
    Did the S5 not have aluminium paddles too - I do not know ? That image looks to have plastic versions.
    The wheel variants that Audi offer is boggling in terms of diameter, width and then trim finishes too.
    26,722
    None of the wheels have aluminium paddles, its just plastic plated/covered with a chrome/aluminium like material & yes the S5 came with those style paddles & I've personally had an S5 wheel which was thicker than standard, so go figure, vag change there minds so often its impossible to keep up with there ideals of what should & shouldnt be lol.
    Apr 2012
    N. Wales, LL22
    1,224
    wonder what the part no on that wheel is... i'll message the seller
    VCDS in North Wales
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,074
    As Nige said.
    When I done this mod I used the blokes existing airbag and loom from his B7 wheel. The A5 and A4 wheels share the same airbag fitment.
    But be advised, I have worked on many A4's and especially the cabs, some seem to use the same wheels from an A3 8P P/N: starting 8P0. In this case, your airbag will not fit the A5 wheel. Confusing I know.
    In any case, if the loom connector is different, then swap the looms over as Nige suggested, or just use your current airbag on the new, provided your B7 wheel is that of an A4 and not A3.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,074
    Quote Originally Posted by Ste_Nova View Post
    If from an A5, the part number will begin with 8T0.
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,147
    Quote Originally Posted by Dannykn9 View Post
    A4 B7's that had an original wheel with part number 8P0 are no different from the later B7's. I suspect what happened is the A3's used the same wheel from 2003-2005 and then changed their fitment so the previous 8P0 then became 8E0 i.e. later A3 wheels will not fit.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    26,722
    Later A3 wheels will fit, infact most if not all fit all audi's as spline is same, but the airbag eg. comes in 2 flavours for the shield type wheels fitted to B7's 8P post late 04, Q7, A5 etc etc, where they for a short time added 2 studs on bottom of the airbags that were IMHO used as purely an alignment locator as such, but if attached to the same wheel that catered for, this will fit all the same cars as mentioned already with correct airbag loom as they're all dual stage aswell.
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,074
    Quote Originally Posted by Wrath View Post
    A3's 2003-2005 (split grill 8P1) had a completely different wheel all together mate, they were similar to the B6. A3's 2005-2008 (8P2) had the same style wheel as the B7, but different airbag fitments. 8P0 is the code giving to A3 parts. On all A4 saloon cars I have worked on, the airbag fitment was different and the wheel p/n: began with 8K0 which represents the B7 A4, also 8T0 in some cases. But as said, the cabs seem to use the A3 8P0 wheel, thus meaning I can use an A3 8P0 airbag if needed.
    Don't think the A3 has never used the 8E0 for its part number, even on the 8P1. I could also be wrong, but pretty sure the 8E0 is the older style wheel on the B6?
    Why Audi make things so confusing is beyond me, lol.
    V6 Quatt's Avatar
    Feb 2008
    742
    Thanks Guys
    Thanks Dannykn9 I have sent you a pm
    Torque the Torque
  1. Audi Flat Bottom Multifunction Steering Wheel With Alu Paddles and Airbag
    By ru4shaw in forum For Sale/Wanted - Audi Parts
    Last Post: 11th July 2012, 11:21
  2. Anyone know how to replace standard steering wheel with paddle shift wheel?
    By silverstealth in forum General Technical / How To
    Last Post: 14th October 2009, 06:27
  3. Symphony 3 with multifunction steering wheel
    By Detector in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th May 2007, 22:12
  4. Symphony 3 with multifunction steering wheel
    By Detector in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 25th May 2007, 10:28
  5. steering wheel with radio controls
    By rasA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th April 2005, 23:17
