JMB RetrofitsBadger5
Results 1 to 15 of 15
    May 2010
    colchester
    223
    Anyone fancys a job for a drink wink wink
    Hello,I am in the Essex area and I'm not to mechanical minded so I would like to give someone drink tokens to clean my egr valve and my turbo as I think my vains are sticking,iv seen a mr muscle thread that looks like it works and would like this done,sound like the problem I have with my car at 2000rpm with the mr muscles trick has fixed problems like mine'i If anyone is interested pm me cash waiting.....
    May 2012
    RETFORD, NOTTS
    1,753
    I think if you search you will find a enough pictures to guide you through both jobs. Im not sure anyone would be willing to use mr muscle on another car, i certainly wouldnt risk it!
    Mar 2012
    Essex
    118
    What model have you got? If it's a 2.0 it's fairly easy. If it's a 3.0 then it's a bit more difficult!
    May 2010
    colchester
    223
    2.0 mate not to good with stuff like this lol
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    just about, right here!
    3,756
    Quote Originally Posted by L3WJX View Post
    thats a defeatist attitude! use the guides on here and have a few beers at the same time!
    save a few quid and gain knowledge mate!
    27,129
    Its not a 5 minute job & tbh the Mr Muscle way is only a temp solution if it actually works aswell, best bet is to remove turbo & clean it properly.
    May 2010
    colchester
    223
    Cheers for the replys guys,just spoke to my friends boss who is going to clean the turbo take it off and clean the egr valve for £200' does this sound about right,
    May 2010
    colchester
    223
    Egr valve has now been blanked still the same poor mpg white smoke out the back And still shakes at idle,I'm now thinking injector or loom what's best to do ?
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    642
    Re: Anyone fancys a job for a drink wink wink
    Honestly I dont think its worth £200. Firstly with that money i can get an indy to change clutch and flywheel. If u are going to go ahead I hope you get him to clean intake manifold by bolting it off.
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    642
    Also try BG244 in your tank to see if it makes a difference
    May 2010
    colchester
    223
    Bg244 is in my tank already but still nothing,this is really ******* me off now,engine really shakes sometimes at idle sounds a bit like its running on 3 but no fault codes,mAybe could be running on 3 I have vagcom and checked injectors them self there all between -2.5 and + 2.5 if this is right ...
    Mar 2012
    Essex
    118
    How long has the BG244 been in the tank? You need to give it at least a third of a tank to clean up your system. It won't make any difference straight off.
    May 2010
    colchester
    223
    Woke up this morning to no water in the coolant just went over night had to refill this morning,but I had a head gasket test done but nothing seemed wrong
    Mar 2011
    North Wales
    210
    Have a look under your oil filler cap or on the dipstick for white / yelowish sludge - this would most likely indicate that water is getting into the oil
    27,129
    Also try putting in a dry place & put cardboard/paper underneath to see whereabouts its coming out from, a general area will help trace it, but thats a vast loss of coolant tbh if it was empty.
  1. Anyone fancy an S2 avant? (swap for s3)
    By dest in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2009, 12:06
  2. Anyone fancy a swap of a dension cradle for a cable
    By technics100 in forum In-Car Entertainment
    Last Post: 17th January 2008, 23:26
  3. Anyone fancy a swap? My S4 for an oil burner...
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th May 2007, 20:23
  4. Anyone fancy a TT for 200 ???
    By john2garden in forum General Chat
    Last Post: 28th July 2006, 00:30
  5. Anyone fancy a custom Milltek for A3 with S3 Bumpe
    By nfluester in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2004, 10:31
