Volks AutosMonster Motorsport
Results 1 to 13 of 13
    Oct 2012
    Fuel consumption for a 2005 A4 Avant 3.0 TDI Quattro
    Hi all,
    I was recommended this forum from the Corrado forum, so hoping someone might be able to help with some info / advice!
    I'm after some help / comparison info on my 2005 A4 B7 3.0 TDI Avant Quattro S Line fuel consumption, as since about 2 months after we got it it has consistently run in the low 30s (occassionally high 20s) for mpg, which is far worse that I thought it would be and than it was for the first couple of tanks. I want to try and get some comparative info from others with the 205 bhp engine to see if I am right to be worried, or if it's just to be expected for a four wheel drive car with a 3.0l V6 turbo charged diesel engine....
    I know that some of these engines have injector issues, so I'm keen to make sure if there is anything wrong it gets resolved whilst the car is still under warranty, as apparently the injectors are £400 each! I've already had it diagnosed at an Audi garage, being advised that yes it doesn't see quite right but that all the injectors are within spec, hence they can't replace anything under warranty.
    Additionally, it's not great at starting sometimes, taking 5+ seconds before actually starting, which I'm guessing could also be injector related (i.e. if the injector(s) are leaking, presume it takes longer to build correct rail pressure and hence start....just a guess though and would be great to hear if others start as soon as the key turns or if this is just to be expected of a large diesel engine.
    On a related note has anyone any experience of using the Redex / Wynns diesel injector cleaner type products as was thinking for the sake of £15 or so would be worth a go?
    Am also looking into getting the oil checked to see if there's any diesel contamination of the oil, from injectors leaking down the bores, past the pistons into the sump...
    I am a bit of a geek at times, hence do keep track of the mpg of the car which is as follows - most of the driving is longer journeys, although there are some tanks which were majority town driving, some of the tanks even being long motorway journeys driven at 70 - 85 yet still only returning 35mpg or less. Generally I don't drive the car hard, so had expected better mpg that this. The values are all calculated based on fuel required to brim the tank versus miles driven since last fill, as the car must be one of the very few with only the basic computer, so only displays range (not instant or trip average mpg). I was seriously chuffed with the first tank, but have never made it into the 40s since despite some very sedate motorway cruising trying to maximise mpg!
    Date Trip Miles Mileage Cost litres gallons mpg p / mile £ / litre
    14-May-11 357.0 44139 £50.26 37.81 8.32 42.92
    14.08 £1.329
    24-May-11 393.6 44533 £69.79 52.51 11.55 34.08 17.73 £1.329
    03-Jun-11 420.0 44953 £76.90 55.77 12.27 34.24 18.31 £1.379
    05-Jun-11 308.2 45261 £49.08 37.19 8.18 37.67 15.92 £1.320
    19-Jun-11 236.0 45497 £42.30 32.06 7.05 33.46 17.93 £1.320
    27-Jun-11 432.7 45930 £78.64 57.44 12.64 34.25 18.17 £1.369
    29-Jul-11 304.0 46234 £64.15 44.27 9.74 31.22 21.10 £1.449
    04-Aug-11 224.5 46459 £37.34 28.33 6.23 36.03 16.63 £1.318
    18-Aug-11 313.3 46772 £51.66 39.72 8.74 35.86 16.49 £1.301
    03-Sep-11 413.7 47186 £71.75 57.25 12.59 32.85 17.34 £1.253
    17-Sep-11 234.1 47420 £41.97 32.51 7.15 32.74 17.93 £1.291
    29-Sep-11 353.2 47773 £65.44 46.78 10.29 34.32 18.53 £1.399
    05-Oct-11 347.5 48121 £57.21 43.67 9.61 36.18 16.46 £1.310
    16-Oct-11 364.1 48485 £63.06 47.79 10.51 34.64 17.32 £1.320
    01-Nov-11 400.0 48885 £73.06 55.36 12.18 32.85 18.26 £1.320
    11-Nov-11 327.1 49212 £57.53 43.60 9.59 34.11 17.59 £1.320
    24-Nov-11 352.8 49565 £55.15 44.96 9.89 35.67 15.63 £1.227
    10-Dec-11 394.2 49959 £74.73 53.80 11.83 33.31 18.96 £1.389
    21-Dec-11 310.8 50270 £60.33 45.72 10.06 30.90 19.41 £1.320
    07-Jan-12 423.6 50694 £78.71 58.52 12.87 32.91 18.58 £1.345
    16-Jan-12 385.1 51079 £75.48 53.95 11.87 32.45 19.60 £1.399
    05-Feb-12 314.1 51393 £65.40 49.21 10.82 29.02 20.82 £1.329
    11-Feb-12 236.2 51629 £54.95 36.66 8.06 29.29 23.26 £1.499
    15-Feb-12 336.4 51966 £60.09 44.88 9.87 34.08 17.86 £1.339
    25-Feb-12 393.4 52359 £73.10 55.00 12.10 32.52 18.58 £1.329
    16-Mar-12 418.0 52777 £86.60 58.16 12.79 32.67 20.72 £1.489
    31-Mar-12 205.3 52983 £44.04 29.58 6.51 31.56 21.45 £1.489
    10-Apr-12 312.0 53295 £61.10 44.07 9.69 32.18 19.58 £1.387
    28-Apr-12 415.3 53710 £80.57 57.73 12.70 32.70 19.40 £1.396
    11-May-12 157.4 53868 £33.85 24.59 5.41 29.10 21.50 £1.377
    13-May-12 255.4 54123 £47.63 32.87 7.23 35.32 18.65 £1.449
    13-May-12 228.4 54352 £41.20 28.24 6.21 36.77 18.04 £1.459
    26-May-12 289.9 54642 £51.97 41.45 9.12 31.80 17.93 £1.254
    01-Jun-12 261.5 54903 £47.09 33.90 7.46 35.07 18.01 £1.389
    09-Jun-12 452.4 55356 £73.45 56.48 12.42 36.41 16.24 £1.301
    28-Jun-12 412.7 55768 £73.32 56.38 12.40 33.28 17.77 £1.300
    09-Jul-12 425.5 56194 £75.02 54.40 11.97 35.56 17.63 £1.379
    23-Jul-12 322.5 56516 £60.14 45.91 10.10 31.93 18.65 £1.310
    29-Jul-12 205.5 56722 £38.26 29.63 6.52 31.53 18.62 £1.291
    03-Aug-12 400.7 57123 £82.35 55.68 12.25 32.72 20.55 £1.479
    10-Aug-12 143.0 57266 £29.40 20.72 4.56 31.38 20.56 £1.419
    18-Aug-12 411.5 57677 £78.51 54.94 12.09 34.05 19.08 £1.429
    26-Aug-12 222.5 57900 £42.22 31.32 6.89 32.30 18.97 £1.348
    13-Sep-12 325.0 58225 £62.83 43.78 9.63 33.75 19.33 £1.435
    21-Sep-12 224.2 58449 £43.86 30.48 6.70 33.44 19.56 £1.439
    25-Sep-12 485.0 58934 £78.32 58.10 12.78 37.95 16.15 £1.348
    08-Oct-12 326.8 59261 £57.66 42.77 9.41 34.74 17.64 £1.348
    Phil
    dubdemand's Avatar
    VAG Addict
    Aug 2010
    Surrey
    405
    Hello mate, cant offer any help or advice but wanted to say hi as an old member of CF (Phil K). Sold my C about 6 years ago and still miss it
    Went through a few alternatives and ended up here with our B7... although ours has the (problematic) 2.0 tdi engine. I always wondered if the 3.0 would be a good replacement when we need to move this one on though so will keep an eye on this thread with interest.
    Hope you get it sorted!
    2009 A4 2.0 TDI (170) Avant S Line Exec. ​Quartz Grey, S Line suspension, Bluetooth phone prep low, AMI, DAB, Symphony III, Leather/Alcantara, rear sun blinds, heated/dimming/folding mirrors and cruise control. Mods so far: BBS LM (reps), needle sweep and dipping mirror on reverse. To come: spacers, rear window tint and badge delete.
    Jun 2007
    Norfolk
    66
    I have been thinking the same since i picked up my 233bhp Cab in April.
    I always thought there was something wrong as i was never getting more than 35mpg and still the max i have ever had is 37mpg.
    On here there is people saying that they are reguarly getting into the 40's even sititng at 80+ mph.
    I have done the following in an aid to improve the mpg:
    - K&N air filter - no difference
    - Diesel Injector cleaner - about 3-4mpg average
    - V-Power - not really much of a difference, maybe 1-2mpg
    - Cleaned the EGR - that made a couple of mpg more
    - Disconnected the EGR - this made the biggest difference, averaged 37mpg on a tankful
    I have also looked into the injectors, i believe 2 of mine are out of spec, but not massive, so it is on the list to do.
    I also changed all the glow plugs, (about 80 quid) as two showed up on VCDS as not working (no change to fuel consumption)
    Also thinking to remove the DPF and EGR and get it mapped out. After seeing the oily muck that came out of the inlet manifold...
    Over the last 6000 miles i have averaged 34.7mpg
    But i love driving it and looks great!!
    rowdyboy's Avatar
    Mar 2009
    Derbyshire
    802
    Hi mate, welcome to the forum.
    I know you're new on here but this issue has been gone over so many times, have a search and you'll find thread after thread.
    Everyone "claims" different figures tbh. Ive just come to the conclusion that the people who get 40+mpg must be Sunday drivers and hold everyone else up on the road, that's the only way I can get those figures.
    Real world, I get around 32mpg, which if you use the power like I do is pretty good.
    Like I always say, did you really buy a 3.0 V6 Turbo 4wd to worry about economy ????
    3.0 Tdi Q A4 Avant S-Line Dolphin Grey
    RNS-E retrofitted
    ben.w93's Avatar
    Sep 2010
    Devon/Cardiff
    213
    I have had my 3.0TDI for a few months now and recently got it mapped. I can get about 42 mpg on a run sitting at about 77-84 on cruise depending on traffic. Around town I only ever gets high 20s, maybe low 30s depending on how you drive it. It is better on fuel than my previous 2005 2.0TQ, which would only get low 20s around town and high 30s on a run. When I drive it hard, it still does low 30s, and seems to be marginally better on fuel after I had it mapped. To be honest if your really worried about fuel consumption, the best car to get would have been the 2.0TDI, but I would rather have something that is reasonably quick but still relatively speaking ok on fuel.
    2008 A5 3.0TDI
    V6 Quatt's Avatar
    Feb 2008
    783
    Pbradley98 - Have you changed fuel filter, Air filter recently?? I understand your concern
    Yeh good write up.
    Just to say mine is 233ps and around town realistically - 24-27 mpg driving sensibly
    Motorway - 37-38mpg if crusing at 70 mph can return 40 mpg
    Bear in mind it is a heavy car and would be interesting to find out what others get mileage wise when filling up?? so we all can see if we are all averaging the same?? comments welcome??
    £20 -
    £40 -
    £50 -
    £80 -
    I have noticed that sometimes my fuel consuption can be worse at times , It may be depending on what fuel is used, we also have to take in to account fuel prices, tyres etc.. etc
    Some members say you gain more MPG and smoothness if you get a remap.
    At times I feel the car drinks, then sometimes it can be better, however I love the power of the V6 and comming from a 2.0 TDI (140) non quattro the V6 fantastic
    Hope this helps.
    Would be good to get others views.
    Torque the Torque
    Chugger
    North Devon
    2,716
    Try using www.fuelly.com, very easy service to use.
    I took a 57 2.0tdi 170 A4 avant out for a day last weekend, and economy was loads worse than my sportback. I put this down to it weighing more and having a DPF. I would consider high 30s being a reasonable average for such a weighty V6. I would look at getting the DPFs removed and mapped out if you want an increase
    57 A3 2.0 TDI Sportback (140)
    Oct 2012
    Hi Guys,
    Thanks for all the responses and suggestions - I'll follow up on injector cleaner, fuel filter and air filter and see how they go.
    As Rowdyboy points out, I'm not too worried about the economy of the car on it's own, more that after the first couple of months that despite no change in driving style / habits, that the economy dropped which made me think that something had gone wrong with either the engine or drivetrain and I'd prefer to get whatever it is resolved whilst the car is still in warranty, rather than waiting for it to be catastrophic and end up with me footing a huge bill.
    Appreciate that I've started a new thread, but when looking I couldn't find anything around the 205ps engine with a quatto B7 avant, as I think that there are a few differences between it and the 233ps so wanted to get some info like for like so to speak, rather than comparing it to a later version of the engine which I would have thought is not only more powerful but would be more economic as well (for instance it sounds like the 233ps has a DPF, which the 205ps engine doesn't... hence black clouds if you boot it under certain conditions but at least not having one is one less thing to worry about!)
    Phil K - had my C for 7 years now and still can't think of a replacement I can afford that I want more than to keep the C! What did you have?
    Fuel used is Sainsbury's 9 times out of 10, so might try switching to BP or Shell to see if that makes any difference. Interestingly the Audi dealer reckoned that the mpg can drop by up to 10% in cold weather on a diesel, which would go a fair way to explaining why it was so bad in Jan / Feb this year, but still doesn't explain how the first tank obliterated everything else since!
    Any further suggestions or experiences of average tank mileage would be welcome.
    Phil
    Mar 2012
    Essex
    118
    I get the same sort of consumption that ben.w93 gets. BTW, I have a 233ps but no DPF.
    Also, for the sake of £20, try some BG244 fuel additive, you only need the one can, that might clean things up a little - made a big difference on my car in terms of smoothness.
    dubdemand's Avatar
    VAG Addict
    Aug 2010
    Surrey
    405
    Quote Originally Posted by pbradley98 View Post
    Mine was a 2.0 16v... Not a bad drive but not fast either. It was the handling that made it so much fun... Here's a pic of mine taken a few months before I sold up. Think it lives Scotland now!
    Oct 2012
    Great looking Corrado - not surprised that you miss it in the slightest! Mine's a VR and like you say, the handling is great fun and would imagine that the 16V would be better than the VR without the extra weight at the front....
    Mine's a very similar (if not the same - Storm Grey) colour which I really think suits the car.
    Jas - thanks for that - will give the BG244 a try.....
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    Have to say my experiences with a 3.0tdi have been much the same. Mid-High 30's on average motorway runs, 40 - mid 40's if you drive conservatively, and mid to high 20's when being 'enthusiastic'. Plus you have to remember to calculate your actual MPG and not rely on the DIS... which not everybody does...
    But as rowdyboy says, who buys a 3.0 V6 turbo permanent 4WD for economy? It's a lot more economical than a petrol equivalent...
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    Oct 2012
    Just stuck in the BG244, so see what happens with that!
    Quote Originally Posted by jjmurphy21187 View Post
    Think you've missed my point slightly - if I'd always had high twenties / low thirties I wouldn't be worried as like you say I didn't buy a V6 turbo quattro for economy, it's more the fact that it's decreased for no apparent reason from the mid thirties that it delivered initially and that it's currently covered by an Audi warranty, so I'd prefer any major work to be done under warranty (i.e. injector replacement / high pressure fuel pump gremlins etc) to be done for free rather than having to cover the entire cost myself....
  1. 2005 A4 Avant 2.5 TDi SE Heated seats
    By strapkass in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 22nd May 2012, 23:12
  2. 2005 A4 Avant 2.5 TDi cambelt change
    Last Post: 10th May 2012, 13:41
  3. FUEL CONSUMPTION FOR v6 2.4 petrol
    By thebigE in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th November 2010, 11:58
  4. A6 Avant 3.0 TDI Quattro SE for Sale
    By s8craig in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th April 2010, 16:50
  5. A6 Avant 2.5 TDI Quattro 5 cylinder
    By buchan in forum Diesel forum
    Last Post: 21st September 2007, 09:27
