Sky InsuranceVolks Autos
    Aug 2012
    Mr Muscle for B7 2.0tdi
    Hi
    I have been reading the threads with regards to cleaning a b6 1.9tdi turbo with mr muscle. Is there a guide for the 2.0tdi as i cant find one anywhere
    Thank you
    Nov 2011
    171
    Hello. I did this on my B7 2.0 TDI a few months ago, it is really straight forward and came be done really quickly. Remove the engine cover, remove all of the airbox assembly (really obvious how this comes out, just a few screws and clips holding it all together). Then you will be able to see the turbo with the exhaust attached to it. There are 3 bolts holding the exhaust to the turbo, remove these and slide it backwards away from the turbo. You can then squirt your Mr Muscle into the turbo, job done !
    Note that one of the nuts is a bit of a nightmare to remove because of how little room there is to work, just needs a bit of patience and quite a lot of swearing
    I used a WD40 straw to squirt the cleaner in, made it much easier to control and direct.
    Hope that helps.
    Aug 2012
    Thanks very much Oddie did it make much difference to your car? I have been having the black smoke and no power from 1500-2000 with crazy kangarooing.
    Nov 2011
    171
    No problem, you are welcome. My car was going into limp mode, mainly when driving it on the motorway. It would go into limp mode in 5th or 6th when accelerating hard. It has made a massive difference to mine, it hasn't gone into limp mode once since i cleaned it (Touch wood !)
    Definitely worth giving it a go. I am planning on cleaning mine again sometime soon just for good measure.
    Jun 2010
    South Wales
    60
    Cleaning the EGR valve may be a benefit to. That's what sent mine into limp mode. You'd be surprised how much crap builds up in there.
  1. What tuner should i choose for my 2.0TDi 140chp with S-Tronis
    By influxsg in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st June 2009, 22:19
  2. Chipped Uk ST3 for A4 2.0Tdi 140 (3 maps)
    By Audi-do-dat in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 10th June 2009, 13:17
  3. Estimated 95k service cost for A3 2.0TDI
    By ElegantSpoon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th June 2009, 22:50
  4. Question for remapped 2.0TDI drivers
    By benw123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th August 2005, 11:59
  5. Tyres for A3 2.0Tdi Sport
    By imported_Adambsmith in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th July 2005, 12:08
