Thread: Bose setups
    Oct 2005
    london
    24
    Bose setups
    Is there a difference in the bose setup in normal b7's bs the s4/rs4?
    I have bose in my car with a symphony 2 had unit. I have heard the bose in an s4 and rs4 with the rnse unit and they both sounded louder, clearer and more fuller bass.
    Cheers,
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,538
    Quote Originally Posted by yavz View Post
    Nope they're identical.
    That's the difference between the Symphony II and the RNS-E - fit an RNS-E in your car and it will sound just as good.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    27,129
    The rns does produce different sound to the symphony imho, I find the symphony to be more bass orientated tbh mate, the rns seems more crisp/clearer, but I'm not a serious audiophile as such, just can tell the differences between the 2.
    The bose isnt different so thats not an issue.
    If you need a supply/fit solution give me a shout.
    Oops Dave already replied, I was held up by hours of work lmao
    Oct 2005
    london
    24
    I get what you mean NHN, my current setup goes lower but just lack the clarity i heard in the other setup.
    Right. looks like i need an RNSE. I already have the double din setup with my symphony 2.
    Whats needed to ensure my MFSW and Bluetooth etc still work?
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,538
    An A4 RNS-E, a fully wired adapter (the RNS-E uses a Quadlock connector but the Symphony II uses the ISO connectors) and an antenna adapter (the RNS-E uses a dual Fakra but the Symphony II uses a Fakra plus an ISO antenna connector). You can get the adapters from many places (just make sure you get a fully wired one that supports phone, CD and Bose).
    To physically do the swap you'll need 4 of the Audi radio removal tools, and then you'll need access to VCDS (Vag-Com) to recode the Bluetooth module and RNS-E, and clear any fault codes that appear during the swap.
  1. Will S3 8P Bose Setup Fit S3 8L
    By s3_driver123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st January 2009, 22:17
  2. how can i tell if i have a bose setup ?
    By stevess3 in forum In-Car Entertainment
    Last Post: 6th August 2007, 09:49
  3. Bose setup
    By imported_alecblack in forum In-Car Entertainment
    Last Post: 13th January 2006, 23:22
  4. Wiring loom from S3 (BOSE SETUP)
    By danbrier in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2003, 23:53
  5. Aftermarket Head Unit work with Bose setup??
    By dans3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2003, 20:20
