AH FabricationsEM Tuning
Results 1 to 10 of 10
    Oct 2012
    13
    Question Audi A4 Soft Top problem
    Hi there,
    Just bought a A4 3.0 TDI quattro on a 57 plate and the roof would not close earlier today.
    When I tested the car everything worked fine, i bought it private so can't go back.....
    There was no warning signs, and I checked the fuse to be ok. I manually open the roof but found it a struggle to close on my own so put it back in. I tried to close the roof again it worked ok?
    Do you think this could have been a one off and does anyone have any experience with soft tops not closing?
    Thanks and look forward to hearing from you
    Jun 2007
    Norfolk
    66
    I had the same thing with mine, same car too.
    It was the soft top position sensor, now works perfectly. Do you have vcds? where are you located?
    Oct 2012
    13
    Thanks for reply.
    What is VCDS and I live in Gloucester
    Jun 2007
    Norfolk
    66
    VCDS is the audi/vw diagnostic program that will find all the fault codes.
    From there you can find any issues and parts to fix. I was down in Worcester last weekend and i have VCDS. You just need someone to scan your car to find out.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,520
    they sometimes go out of sync
    so by opening and closeing with the tool in the dash resets the roof
    i wouldnt worry if its working
    g12
    Aug 2006
    40
    I doubt it'd be a sensor. Its happened to mine before - would open fine, but then wouldnt close, or would open only to unlock the top and not move any further.
    I fixed this by resetting it via VAGCOM (restore defaults), then to readapt its settings by opening/closing the hood manually 3 times (procedures on the forums somewhere).
    I'd do that before changing any sensors!
    Feb 2011
    Leicester, United Kingdom, United Kingdom
    361
    Quote Originally Posted by Evans94 View Post
    Hi there,
    Get the codes read using vagcom, if there are no codes after resetting chances are its the brushes in the motor sticking. Ive wrote a guide on how to solve this
    Audi A4 Cabriolet Soft Top/ Roof / Hood Motor Repair Guide
    Feb 2011
    361
    Quote Originally Posted by g12 View Post
    Hi, this is caused by the brushes in the motor sticking in their carriers and causing arcing with the commutator, this leads to poor contact. I've just posted a link to a guide how to solve this
    g12
    Aug 2006
    40
    Cheers@VagPro
    I read your guide when I had problems with mine (3 months back). I didn't think it was this as my car had only done 15K miles which is why I did what I did and thankfully its been working since.
    Oct 2012
    13
    Poentiometer was replaced today. All good.
  1. Audi A4 Cabriolet Soft Top/ Roof / Hood Motor Repair Guide
    By VagPro in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 22 Hours Ago, 05:38
  2. Soft top problem
    By plasmaduck in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th February 2014, 13:11
  3. Audi TT Soft top enhancement detail
    By butler2.8i in forum Detailing
    Last Post: 21st May 2012, 23:57
  4. HI from the VW man looking for an Audi Soft-top
    By Ricey155 in forum The Welcome Section
    Last Post: 16th July 2009, 13:04
