Sky InsuranceBadger5
Results 1 to 8 of 8
    g00se's Avatar
    Nov 2010
    Reading
    265
    Weak suspension uprights?
    has anyone had problems with the alloy uprights breaking at the pinch-bolt?
    my drivers side has just snapped (needs a new upright and wheel bearing now), and it looks like the passenger side is starting to fracture too.
    happy friday
    goose
    Current:
    '08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
    '72 Sunburst Yellow VW Karmann Ghia Coupe - 1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 black leather interior
    Past:
    '06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
    Oct 2008
    Glasgow
    431
    They are usually a robust item. They can however become weak if the pinch bolt is removed using great force of heat.
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    826
    I had 2 seized bolts in my front suspension setup which became apparent when I had my springs changed. I've got a feeling the mechanic said they were pinch bolts but I'm not 100%. Apparently they (whatever they are called) are made of steel rather than aluminium as the suspension arm and as such they often seize. Not sure about weakening of them though?
    For reference they were several inches long and partially threaded. One on each side at the top of the suspension arm...
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    Oct 2008
    Glasgow
    431
    Quote Originally Posted by jjmurphy21187 View Post
    Those bolts are the pinch bolts.
    g00se's Avatar
    Nov 2010
    Reading
    265
    heres a piccie i "borrowed" from audizine... my strut broke exactly at the point of the left-hand arrow:-
    i think audi made struts from steel and alloy, but must have decided to put the alloy ones on the V8's to save front end weight?
    goose
    Current:
    Past:
    Oct 2008
    Glasgow
    431
    Thats not ideal, i can source you a set of alloy uprights from a b5 rs4 if needed.
    The b5 rs4 has alloy uprights, and all b6/b7's have them.
    The steel upright was mainly on the b5 chassis (a4/s4)
    Mar 2011
    112
    Guys I think this is where people may be going wrong. On the official workshop manual ELSAWIN it states that these slots are not for prying and should not be spread under any circumstances. This may be weakening the top section.
    When I separated mine it took several days of soaking and working the bolt to remove it, also didn't use any heat. It then took several more days to remove the ball joints from the arm. Rebuilt with plenty of Rocol Anti Seize Compound to aid easy release next time.
    g00se's Avatar
    Nov 2010
    Reading
    265
    Quote Originally Posted by Custardsucker View Post
    just to be clear.. i borrowed that photo. i didnt put the text on the pic, nor would i recomend prying the pinch-bolt!
    i used that photo just to illustrate exactly where my strut fractured and snapped
    cheers
    goose
    ps. drivers side was replaced on Friday, am waiting for the bill to see if i can get the passenger side done before ADI on Sat!! Do not fancy hammering round a clockwise Castle Combe if the PAX side suspension is weak
    Current:
    Past:
  1. WANTED: N/S front suspension upright
    By Jason.s in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th May 2011, 15:02
  2. TTC 225 Suspension mods
    By CarloTT in forum TT/TT-S/TT-RS Forum
    Last Post: 22nd January 2003, 23:30
  3. A3/S3 Suspension Component Parts
    By AL_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th January 2003, 16:47
  4. Suspension parts VW?
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2003, 00:44
  5. Imported S3 Suspension
    Last Post: 8th January 2003, 00:33
