    Nottingham
    72
    Wheels - width and offset question!
    I brought a set of genuine 19" speedlines advertised as 8.5j et48 with 235/45/19 tyres, of which two were at the legal limit.
    I picked them up, checked that they weren't bent or cracked stuck them in the car and got home and put them straight in the garage.
    FFWD to last night when I thought I would double check the width and offset before ordering a set of spacers ready to get the wheels centres painted and found that they are actually a 19x9j et33 wheel with 255/40/19 tyres.
    My car is an 06 Quattro Saloon (3.2 if that makes a difference) S-Line so the questions are
    I know that et33 should work, but with the width being 9" is that too much?
    assuing that the rim width and offset work what size tyre do I need?
    Thanks in advance!
    Simon
    Volume is nothing without control
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    823
    With the 3.0tdi you need atleast ET40 to clear the brake calipers, not sure if that will be the same on the 3.0 petrol but I'm guessing you'd have the bigger brakes also. a 5mm spacer and ET33 would give ET28... which might stick out of your arches. Probably be best off using a slightly stretched tyre to avoid rubbing on the arches.
    Hopefully someone with some 9j rims will be along soon to give you some definate input. Is your car lowered at all?? That might make a difference to what is suitable if it's a close-call
    225/40/19 on a 9j rim is a reasonable stretch... I have 235/35/19 on an 8.5 and it's got a slight stretch. They don't sound like the 'correct' tyres for those rims...
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    Nottingham
    72
    just edited my post to say the current tyres on the wheels are 255/40 not 225!
    oh and at the moment I am on standard S-line suspension, possibly going to change to the b5 perch at the front but I swore I wouldn't modify this one....
    Tiptronic
    Jun 2010
    Nottingham, UK
    823
    That sound a bit wide to me... I thought 245 was a reasonable limit for the B7 A4? I could be wrong though. Especially if you're going to keep it stock.
    Quote Originally Posted by Simon View Post
    Did you ever honestly believe that was going to happen?
    Where abouts in Nottingham are you Simon? Going to ADI?
    Nottingham
    72
    I'm in Cinderhill, no plans to go to ADI.
    My last modifying outing cost me the best part of £20k and and ended up with a 450bhp RWD monster and three written off cars! This Audi is supposed to be my sensible choice while I save up for an Aston (or a Nissan GTR)
    quattronly
    Jun 2011
    SW Scotland
    105
    Quote Originally Posted by jjmurphy21187 View Post
    I'm on 245/40 R 18 at ET 45 on my S line. 245/35 R 19 is less than 2mm larger radius and wouldn't foul on my wheels, but that offset might be an issue on the outside.
    255/30 R 19 is a bit smaller diameter than my stock setup, but makes the wheels very vulnerable.
  1. Wheel pcd and offset.
    By Harribo66 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th April 2012, 21:19
  2. Width and offsets!! N8?!?!
    By basssound in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd May 2011, 13:30
  3. Wheel refurb and tyres question.
    By mitalm in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th June 2010, 09:36
  4. General Wheel Width and Offset Question...
    By PNH80 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th September 2008, 14:25
  5. Alloy width and offset 18"
    By Ryanc in forum Handling
    Last Post: 24th April 2005, 11:32
