Chris NottMonster Motorsport
Results 1 to 8 of 8
    May 2011
    195
    Flickering headlights
    I noticed my interior lights and headlights were flickering ever so slightly. It has never done this before. No warning lights etc.
    Any suggestions why it does this.
    Regards
    Lee
    27,007
    When did this happen, when starting car?
    Battery on its way out?
    May 2011
    195
    Does it all the time to be honest although not as noticeable when driving
    27,007
    So when you just turn ignition on but dont start the car, does it do it then?
    May 2011
    195
    I'll check that buddy. Take it if it flickers then the battery is going?
    27,007
    Battery or alternator would be 2 things to check.
    Jul 2012
    Lincoln UK
    14
    I've now got the same fault after changing my side lights out from std ones to 501 LED's. slight flicker no matter if the engines running or not or if its just side lights on alone or together with headlights. Any ideas?
    27,007
    Yeah, remove the led's.
  1. flickering headlight
    By bez101 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th December 2012, 09:29
  2. Flickering Headlight - Please Help!!
    By KGB in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th September 2012, 20:58
  3. flickering headlights that turn off, when driving!!
    By slowcoach3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2011, 21:09
  4. Headlights flickering
    By Gary b in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th January 2010, 18:56
  5. flickering headlights
    By Vikz in forum In-Car Entertainment
    Last Post: 15th September 2006, 00:30
