Badger5Volks Autos
Results 1 to 9 of 9
    May 2012
    27
    Headlight Switch Question
    Did a search trying to answer this but couldnt find anything usefull.
    I am trying to retrofit front foglights to my DTM and went to try the install tonight. I have got a genuine loom and a new headlight switch with the auto function and both front and rear fog positions part number- 8E0941531b (DTM switch only has rear posistion on the switch).
    I fitted the loom and the new switch and turned the car on two clicks on the key and the main beam came on straight away even though the switch was in the 'O' posistion and stayed on untill I removed the key. When the switch is in the auto posistion the headlights came on (was dark at this point) and went off when the key was turned to the posistion where you can remove it as it should. When the switch is turned to the sidelight posistion the main beam stays on and the symbol on the switch stayes red. When the switch is in the main beam position the main beam is on but the dis throws up a numberplate bulb out warning (both bulbs are on though). The fogs work both front and rear as they should do with the switch in each position.
    When I refitted my original headlight switch all went back to working as it should with the exception of the front fogs came on as well as the rears when the switch was pulled out to the rear fog posistion.
    I tried coding the 'Fog Light Cold Diagnosis' to '0' in channel 16 in central electrics using VCDS but it didnt change anything.
    So my question is does anyone have a wiring diagram for this new switch or the plug that goes into it, or can show me pics of how their switch is wired?
    Any help would be greatly appreciated.
    Dec 2011
    Glasgow
    195
    I'm guessing that the two switches are wired differently so you should check the differences between the 2 wiring diagrams
    I have no personal experience of this it's just something that I've read other users on here have done and that's if you disconnect the switch the lights come on permently as standard as a safety precaution. Which to me suggests a wiring difference between the 2 switches.
    A4 B7 2.0ltr TDI Cabriolet
    Mods
    Puddle lights Illuminated cup holder Cd changer in glove box Interior lighting led upgraded
    Full VCDs
    May 2012
    27
    Does anybody have a wiring diagram for this switch or know where I can find one???
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    did you already have auto lights ?
    May 2012
    27
    Yea, already had auto lights, only thing that's different is the front fog position on the new switch.
    bez101's Avatar
    Jul 2008
    8,491
    strange
    last DTM i added fogs was plug and play with the correct loom
    all i needed to do was activate the fogs
    May 2012
    27
    strange
    Did you change the switch for one with two positions for front and rear fogs? My original switch would work, it just operates both front and rear fogs at the same time as it only pulls out once. Just not sure how MOT legal that is :S
    bez101's Avatar
    Jul 2008
    8,491
    yeah changed that i got q from a B7 on same year
    i know sometimes that light switch is diffrent
    what was yours from
    May 2012
    27
    My cars a 55 plate but not sure what year the replacement switch is from. All the eBay ad said was that it was from a B7 RS4. Part number reads:-
    8E0 941 531 B 01B - K07740 BK7.
    If that tells you anything?
  1. quick question, headlight switch
    By scott b in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th November 2010, 01:21
  2. headlight bumper question
    By quattroa6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 6th January 2008, 08:23
  3. HEADLIGHT SWITCH ANY IDEA PLEASE
    By HOUCH in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2006, 11:04
  4. A3 pic + door switch question
    By MsK in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2004, 13:34
  5. headlight switch how-to
    By NxJxHxCedge in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th May 2004, 10:56
