Badger5Volks Autos
Results 1 to 18 of 18
Like Tree1Likes
  • 1 Post By VagPro
Thread: poor starting
    May 2012
    93
    poor starting
    when the car is first started in the mornings it struggles a bit, i have put new glow plugs in and new fuel filter but still the same.
    it only does this on the first start when cold,any other time it is fine. it is a 2.0 tdi.
    any help would be appreciated
    thanks
    Mar 2011
    North Wales
    207
    Have you had new injectors / loom fitted ?
    Mine has been the same since having those
    May 2012
    93
    Quote Originally Posted by mm707 View Post
    no, no new injectors or loom, its 2005 model.
    i_786_i's Avatar
    Aug 2012
    57
    Mine had a poor start when using cheap diesel... flushed out the old stuff with quality fuel and treatment, been better ever since
    Also you should press the clutch when starting for a better start (if yours is a manual).
    Living a little!
    London
    181
    Quote Originally Posted by hubbo1 View Post
    thanks
    Worth testing your battery.
    I suffered poor starting a little while back thought it may be Glow plugs. Put my CTEK battery conditioner on my battery to feed it some life but it came up (!) showing it was DEAD!
    I purchased a new Bosch S4 battery for my A3 2.0 TDI and now it kicks over first time without any hesitation. Glow plugs got sent back.
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    728
    Unrelated I know, but I have to press the clutch to start mine anyway??? Does everyone else??? Also mines a little slower starting now its turning cold. Hope you get it sorted mate
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    Feb 2011
    Leicester, United Kingdom, United Kingdom
    358
    thanks
    Whats the mileage, could be the coolant temp sensor as this tells the ECU what the temperature is and determines how long the glow plugs should stay on for...
    rizzini7 likes this.
    May 2012
    93
    i have changed the fuel temp sensor, made no difference, so should i now change the coolant temp sensor?
    Jun 2009
    186
    Just heat the glowplugs twice. Key in, glowplug light out, turn off, key in, glowplug light off, start.
    Jun 2009
    186
    ... sounds like battery though.
    Feb 2011
    358
    Hubbo,
    See page 34 in document below, the Engine Coolant Temp Sensor and Glow Plug relay dictate the glow plug duration. The fuel temp sensor does not seem to have anything to do with the glow plug system....
    SSP_316 The 2.0 ltr TDI engine
    May 2012
    93
    thanks for that! new coolant temp sensor orderd!
    Jun 2009
    186
    Id be surprised if it were the coolant temp sensor as the temp reading doesnt get to operating temp (90) when its knackered and/or the heater doesnt get hot.
    Feb 2011
    358
    Hubbo, not saying that IS the fault but it does have an input to the glow plug glow duration.... it could also be a bad battery and I have come across the 2.0TDI's with a weak starter motor, leading to not enough RPM's to commence fuelling (However this problem occurs when the engine is warm)
    May 2012
    93
    yep i understand, no issues when car is warm, battery all good, its only the first start in the morning-will let you know when i have changed the sensor.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,492
    id say batt aswell.
    May 2012
    93
    ok, tested battery this morning-12.24 volts, with engine running was 14.56 volts, is 12.24 volts good or bad?
    Jun 2009
    186
    Sounds fine, battery may not be great in the CCA dept. thats why it turns over slow when its cold and fine when warmer. Can try cleaning terminals. Tdi engines pull more from a battery than petrols so need bigger batts. CCA = Cold Cranking Amps.
    How old is the battery, has it done this since ownership? Check type and CCA.
  1. poor starting
    By samuelt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th April 2008, 11:03
  2. Poor starting
    By 1animal1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th January 2008, 20:46
  3. poor starting
    By a3guy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th March 2007, 21:44
  4. a4 quattro poor starting
    By rusraf in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th November 2006, 21:40
  5. Poor starting / white smoke
    By Amchlolor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th August 2006, 21:49
