poor starting since injectors changed
mm707
North Wales
Hi,
Anyone else having problems with poor cold starting since the injectors / loom were changed ?
I am and I'm wondering if there may be a problem with the wiring loom which connects injectors and glow plugs ?
Do you mean it takes an extended period of cranking when cold??
Mine does this but only from time to time.
I'd like to solve it but as it only does it now and again its difficult to identify the cause. No fault codes stored either.
yes - it takes too long to actually fire up, only the first time from a cold start - the rest of the day is usually fine.
