    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    Why is the 2.0tdi cabriolet single cam 8v
    I've known this for a while, it doesn't bother me I just wondered why, I also want to clean the egr valve but it's completely different to all the write ups on the Web.
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,947
    same as why the 18T has got 5 gears
    Dec 2011
    Glasgow
    187
    RHM1Cab
    I cleaned the egr valve on mine
    Quite an easy job it requires a Allen key and it's located to the left of the oil cap
    It slides in sidways to the exhaust manifold you undo 3 Allen key bolts and it slides out unplug the connector and then clean the valve with carb cleaner
    Once clean I just re installed it
    I never found any write ups on the net for this type of egr valve
    I checked elsawin to confirm and that is the egr valve
    Here's some before and after photos
    ImageUploadedByTapatalk1347482192.180434.jpgImageUploadedByTapatalk1347482219.740191.jpgImageUploadedByTapatalk1347482254.284349.jpg
    A4 B7 2.0ltr TDI Cabriolet
    Mods
    Puddle lights Illuminated cup holder Cd changer in glove box Interior lighting led upgraded
    Full VCDs
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Re: Why is the 2.0tdi cabriolet single cam 8v
    Quote Originally Posted by Gazthesparky View Post
    RHM1Cab
    :thumbup: did it make any difference.
    Strange the way they differ from model to model even with the same engine.
    Mate of mine has just picked up a porsche boxster as a weekend toy and it's only 5 speed.
    F
    Dec 2011
    Glasgow
    187
    It didn't seem to make much difference if I'm honest, but it's good to know its clean.
    There is also another valve nearer the windscreen the one which has a squarish box on which pokes through the plastic engine cover. I tried to take it off to clean but i was unable to get at the screw to undo it. I'm not sure exactly what it is but Im guessing it will be covered in carbon so next time Ive got some spare time I'm going to investigate :-)
    Mods
    Full VCDs
  1. Why does the Sportback have different rear lights?
    By mark88 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th June 2006, 01:28
  2. what happened to the 2.0Tdi Revo'd graphs
    By marriedblonde in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th December 2005, 23:42
  3. Why was the wing on the TT put on the car?
    By scooby555 in forum TT/TT-S/TT-RS Forum
    Last Post: 10th February 2004, 19:49
  4. Why did the boost fail ?
    By rickquattro in forum General Technical / How To
    Last Post: 24th December 2003, 19:33
