EM TuningAH Fabrications
Results 1 to 11 of 11
    Jun 2012
    7
    Help PROBLEMS Juddering 2.0 TDi 170
    Hello there I have an audi a4 avant 2.0TDi 170 and I am having a few problems
    I have read hundreds of threads on the internet about 170s and problems and I hope you can help me with my latest one.
    The problem is the car will not accelerate when put foot down in all gears the car just judders like mad and takes ages to drive, this happens in all gears but will accelerate v slowly if just hold foot at about quarter throttle.
    If I am above 2000 revs in all gears then put foot down hard the car wont judder but just feels like is not boosting and accelerates like a non turbo.
    This only happens when car is warm if car is cold for first couple mins only of the drive, the car will fly like a 170 should but goes straight back to the symptoms after about 3 mins driving.
    The car has had
    new turbo - last year
    new egr - last year
    new DMF
    Injectors x2
    vacuum unit on inlet
    cleaned egr numerous times
    couple fuel filters - with no signs of oil in the filter
    checked Vac pipe lines
    The car has been in garage all week for latest set of injectors which i will be beginning my fight with Audi uk tomorrow to get money back, and the garage don't have a clue for the problem. On VCDS (VagCom) it shows up nothing all values on measuring blocks are correct even when driven and there are no fault codes so I have no idea what is going on please can you help ?
    Many Thanks
    Jason
    Feb 2012
    West Wales
    161
    My 170 is doing something very similar.
    Cold it isn't as noticeable but I believe it still does it. Once warm its juddering most noticeably in the lower gears. Part throttle its fine but foot down - judder. Its also intermittant as to how bad it is. Sometimes its a just a little stutter when flooring it other times the whole car shakes.
    According to Audi they replaced all the injectors and the loom on mine in March. I've had the DPF, EGR and EGR cooler removed.
    Booked into a local indy for Monday to see what the score is.
    warren_S5's Avatar
    Oct 2007
    7,166
    My borther in laws 170 TDi A3 has just been into Stratford Audi for an injector loom replacement but it's still juddering at low speeds. We tried an extended run at high revs to try and clear DPF, but it doesn't seem to make much difference. Someone suggested checking the throttle body (clean up), but sounds like a PITA. He's run injector clean up and has literally given up knowing where to go next. Shame as it ruins the ownership experience on a car that's literally just tripped out of the warranty period.
    Jun 2012
    7
    Thankyou for your replys :-)
    I would be interested to hear your out come of the indy garage if possible hopefully its good news for you.
    Your right it really does ruin the experience of owning an audi tempted just to get it fully sorted and sell on quick before next 'well known' problem goes :-(.
    Mine has cut out fully again and towed to audi again so hopefully they can have another go at fixing it will keep all updated.
    Feb 2012
    West Wales
    161
    Sep 2012
    24
    I had the same problem with my A3 TDI 170. All four injectors and the loom were replaced 6 months ago.
    No drama though, as Eddscott suggested, I spent £15 on a new fuel filter and it's made the world of difference. Simple 10 minute (but messy) job.
    Definitely worth a shot.
    Scottyt's Avatar
    Jan 2013
    12
    My a3 2.0 tdi is juddering too usually in 1 and 2 gears the revs go up and down abit almost like its holding back then all of a sudden it rites itself and away it goes its a dsg by the way but had gear box tested no faults, have changed the fuel filter its a little better any ideas on where to go next?
    Jan 2013
    Quote Originally Posted by Scottyt View Post
    it sounds to me like a flywheel problem mate
    Scottyt's Avatar
    Jan 2013
    12
    Shouldnt be the flywheel because had new one fitted about a thousand miles ago along with clutch and oil pump and oil cooler?
    May 2011
    195
    I'd say fuel filter as well buddy.
    Purdy99's Avatar
    Nov 2012
    Bristol
    90
    hey guys, just posted this in a lumpy idle thread, but this can also help with driveabilty as it did with mine, cheap and easy to do, just click the link and look what i posted, audi a4 tdi 170 lumpy idle
    regarding the EGR valve gasket mod,
    also tho i had a very nasty judder in mine, when you put the foot down, turned out it was the torque limiter cutting in, however i notice this is quite an old thread so you may of all sorted out the problems i hope,
    Camillia Well don't want to just settle for any average joe now!
    Purdy haha good point, but then again... apparently anything better doesn't exist
    Camillia No it doesn't... Hence why I'm complaining about it... Come on Purdy you can't be this stupid lol
    Purdy lol the hidden point i was saying, is surely it would be smart to stop chasing what doesnt exist.... then maybe... just maybe! it would shut all you girls up who moan about men...
    Camillia Touché
    Classic case of Girls Moaning about Boys...
  1. Cold start problem - A3 2.0 TDi 170
    By matt_t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st February 2014, 00:12
  2. HELP PLEASE WANTED. AUDI A3 TDI 170
    By stubaloo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th October 2011, 19:34
  3. HELP PLEASE WANTED. AUDI A3 TDI 170
    By stubaloo in forum General Automotive Chat
    Last Post: 9th October 2011, 19:06
  4. Help ! 2007 b7 a4 tdi 170....engine will not turn over
    By vw754 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th August 2011, 19:54
  5. Buying A3 TDI 170 Help!
    By Neddy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st August 2009, 09:26
Tags for this Thread
