JMB RetrofitsAH Fabrications
    jakeyb2525's Avatar
    Aug 2012
    9
    Audi A4 3.0 TDI quattro dsg gearbox help
    Hi i have just bought a 2006 Audi a4 convertible 3.0 tdi quattro, the car drives up to 3rd gear then slips in any gear after that.
    I called the main dealer and they told me my gearbox code for the car is JAX.. so ive hunted down and found a 2005 saloon JAX 3.0 quattro box for £700 from an audi breakers, i have had a few quotes from local garages to fit it one saying that it will need to go to Audi to be pressure filled with oil and have the gearbox ECU programed to the car.
    I am just after a little help from anyone who may have fitted a gearbox to this spec car, is there anything i should know or look out for..? will the car have to go to Audi for the above..? or will the box work just after being fitted..?
    any help would be great.
    cheers Jake
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    825
    The JAX box is the same as mine, the tiptronic one (NOT multitronic). And that sounds about right. It's a sealed unit and the oil should not be changed as the ECU is mounted within the box itselt, however if the ECU has to be programmed to the car it may need to be drained to gain access to the ECU. A specialist would probably be able to drain and re-fill the oil, but recoding the ECU to the car can only be done by Audi. This is going by experience of replacing the HPFP on my old 2.5tdi, has to go to Audi to be recoded also.
    Note: It isn't a DSG box.
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    V6 Quatt's Avatar
    Feb 2008
    785
    Good Point jjmurphy, do you know wether the Gearbox oil needs to be changed in our Tip tronic Gear Boxes??
    Torque the Torque
    Tiptronic
    Jun 2010
    Nottingham, UK
    825
    Transmission fluid in the Audi A4 B7 tiptronic auto-box should NOT be changed. It has the potential to cause many problems and a specialist I spoke to said he's had customers with problems after the oil has been changed.
    Might be best to speak to Audi on this one, you could be looking at a BIG bill in the long run...
    jakeyb2525's Avatar
    Aug 2012
    9
    ok..This sounds like its going to be a nightmare, lets just hope the box ive bought is all ok with oil in tak etc
  1. Audi A6 2.5 TDI Quattro - Engine Removal Help (Broken Cam Followers)
    By Craig! in forum General Technical / How To
    Last Post: 17th December 2010, 15:39
  2. Audi A6 2.5 TDI Quattro - Engine Removal Help (Broken Cam Followers)
    By Craig! in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 9th September 2010, 15:05
  3. Replies: 0
    Last Post: 16th December 2009, 15:53
  4. Audi A6 3.0 TDI QUATTRO 2004 Immobiliser fault
    By marabass in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th April 2009, 12:46
  5. Buying Audi A4 2.5 TDI Quattro
    By gc2318 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd December 2006, 08:48
