Volks AutosJMB Retrofits
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By stuiwhite
Thread: Lowering car 40mm - Spacers required?
    stuiwhite's Avatar
    Jul 2012
    Bristol
    52
    Good afternoon all!
    I am having my car lowered Saturday on 40mm Springs,
    My car has the standard 16" wheels (Like these on ebay: Genuine Audi A4 16 inch Alloy Wheel and 205/55 R16 BridgestoneTyre 6mm | eBay)
    The Offset is ET42,
    Will i need spacers after lowering or will the wheels be fine?
    I just don't have the money yet to by new wheels ....
    Any advice would be much appreciated,
    Stuart
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    822
    Should be fine on 16" wheels. What width are you tyres? People have 45mm drops with 18" & 19" rims all the time with no rubbing issues so you should be well within your limits.
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    stuiwhite's Avatar
    Jul 2012
    Bristol
    52
    Hi!
    The wheels are exactly the ones in the eBay link, so they are: 205/55 R16
    I was more concerned about the inside of the wheel making contact with the inner arch?
    Or will the spring not cause enough camber to make this occur?
    Really appreciate your advice
    Stuart
    Mar 2009
    589
    Quote Originally Posted by stuiwhite:1672908
    Hi!
    Stuart
    You will be fine thats not a big drop !!
    stuiwhite's Avatar
    Jul 2012
    Bristol
    52
    Thanks guys - really appreciate your help,
    I put my hand behind the wheel and was just worried that if camber was going to occur too much it would rub on inside.
    You guys think the following would cause any undesired effects after lowering 40mm:
    Fronts:
    8.5" X 19" ET35
    Rears: 9.5" X 19" et35
    Again - really appreciate you putting my mind at ease!
    *Will post pics up when all done and fitted if you think ill be ok
    Stu
    Tiptronic
    Jun 2010
    Nottingham, UK
    822
    not sure on the 9.5", but I've got 8.5" 19" with 235/35/19 lowered 30mm and no issues at all. I know 45mm drops with 235/35/19 is common and causes no problems, ont sure about 9.5" though... it might be close.
    What engine do you have? For the additional cost of tyres etc you might be better off with 8.5" for piece of mind RE the clearance and also costs when it comes to putting rubber on them... if you don't need the additional width?
    Most alloy wheel places will say 9.5" is too wide for the B7, thats what they told me anyway, but what you want is someone with them fitted to give you a real summary of any problems they've had. Any reason you'd pick the 9.5" over the 8.5"??
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    the 9.5 look better
    Mar 2009
    589
    Some of the yanks run 10 with coils all the way down but I think they have rolled and pulled the arches a little
    Tiptronic
    Jun 2010
    Nottingham, UK
    822
    They do looks better, but a lot of people wouldn't notice the difference between 8.5" and 9.5" unless you pointed it out to them.
    Do you know if the 9.5" fit alright when its lowered Bez?
    stuiwhite's Avatar
    Jul 2012
    Bristol
    52
    Its some BBS LMs that are staggered im looking at ;-) common on these i know but i love the look.
    I was given a pic of identical car to mine (1.9 tdi SE) by a dealer.
    Ill put up the pic when i am not on my iPad.
    Cheers guys i appreciate all your input!
    Stuart
    stuiwhite's Avatar
    Jul 2012
    Bristol
    52
    Image sent to me:
    stuiwhite's Avatar
    Jul 2012
    Bristol
    52
    Hello B7 owners!
    Well finally had car lowered 40mm and fitted some 19" BBS LM Reps.....
    Car is not too low and is very useable. Offset is ET35 and think it looks great!
    Here's a before and after of my car!
    stuiwhite's Avatar
    Jul 2012
    Bristol
    52
    Some more of the wheels:
    g00se likes this.
    Aug 2012
    54
    What suspension setup did you go for?
    stuiwhite's Avatar
    Jul 2012
    Bristol
    52
    I went with 40mm Springs from Apex,
    I did a lot of reading across many different forums and the reviews were mixed.
    I have had no trouble with them and think they are just fine
  1. Lowering past 40mm. Handling, suspension geometry & component wear?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2005, 16:17
  2. knocking noise from front after lowering car
    By TDI in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th July 2005, 18:16
  3. Spacers required for FK Highsports?
    By HTC in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd June 2005, 08:34
  4. A good idea for lowered cars? I think so!
    By in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2005, 10:47
  5. lowering car
    By ImportRacer in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th August 2003, 13:46
