AH FabricationsVolks Autos
    Sep 2012
    A4 B7 Front Suspension Knocking/Clonking
    HELP!!!!! My A4 has got an awful clonking on the front suspension on the nearside. I ve recently had 2 new driveshafts fitted as the originals were shot. it was clonking before i had them done, and continued afterwards. I had the suspension checked whilst it was apart but nothing was found. The noise is gradually getting worse now. Can anyone shed any light as to what it might be? Is this a common problem??
    Jul 2012
    anti roll bar drop links?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,680
    Steering ball joint?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Jun 2010
    South Wales
    69
    You sure it's not a broken spring
    Sep 2012
    I thought it sounds like it could be a broken spring by the sound it makes? I had the car checked out at the garage today and they said everything was tight and as it should be, which has annoyed me now cos i was hoping theyed find at least something wrong.It sounds bloody awful,and i know something isnt right with it. Looks like im gunna have to make the trip to the dreaded local audi stealership to see if they can find the fault
  1. front drivers suspension knock
    By 205man in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th December 2010, 18:56
  2. knocking/popping sound from front suspension
    By Plunky in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st November 2010, 21:38
  3. Front suspension knocking
    By bonerp in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th March 2008, 21:07
  4. Knocking on the front suspension !!
    By 951 in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th August 2007, 10:26
  5. S3 Front Suspension Knock
    By gdwood in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th July 2004, 12:25
