JMB RetrofitsEM Tuning
Results 1 to 24 of 24
    Sep 2012
    16
    SOMEONE PLEAASE HELP IN CAR PHONE 3.0 B7 A4
    I have recently bought the 3.0 A4 s-line and i am curious about how to get the in car phone operational. I need to order the holder and the phone and where do i get this from and what exactly do i need to order. ??
    Nov 2008
    389
    If you've got the phone prep youve also got Bluetooth so don't necessarily need the holder as long as you've got rns-e sat nav or multi-function steering wheel to control the calls...
    Work: A3 Sportback Black Edition 2.0TDI Home: A4 Avant 2.0 TDI Quattro S-Line
    Sep 2012
    16
    What do you mean by the phone prep? i dont have the sat nav but i do have the multi function steering wheel.
    Nov 2008
    389
    I presumed by 'in car phone' you have the blank plate either on the dash or in the armrest?
    Sep 2012
    16
    its the one in the armrest.
    Nov 2008
    389
    Cool. Then should be as simple as turning on the ignition, scan for bluetooth devices on your phone- usually comes up as Audi-UHV or similar in the list. Default pin is usually 1234 - should pair with phone then you can make receive calls through the cluster using steering wheel
    Sep 2012
    16
    excellent thank you very much i will go and try that right now and see how i get on and let you know what happens.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Is this not covered in your owner's manual?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Sep 2012
    16
    probably i have not read it little bit due to laziness and i was on here anyway!
    Aug 2012
    Glasgow/Scotland
    19
    I was in the same situation last week. Get in the car and search with your phone. Passkey is 1234.
    Sep 2012
    16
    Yeah I have got it to work now I was trying it before but putting 12345 as the pass key but 1234 worked fine. I was using an iPhone to do it with and to answer you still have to push the answer button on your phone or is there any other way.?
    Nov 2008
    389
    You dial and answer using buttons on the steering wheel
    Nov 2008
    389
    The left-hand thumb wheel pushes in as well as spins. Spin to choose from address book and push to dial. Push to answer a call too. Numbers/names appear in the DIS
    Sep 2012
    16
    Excellent thanks very much
    May 2011
    195
    Stupid question but how do you know if its bluetooth or not, mines in the armrest.... i did a scan on me phone but it didnt pick anything up!!
    Nov 2008
    389
    As far as I'm aware as I've never come across one that isn't - Bluetooth and phone prep always coexist as the phone module is standard and only difference is that phone prep includes a physical cradle.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,533
    Quote Originally Posted by phil_w View Post
    The very earliest Audi phone module (in 2004) didn't have Bluetooth, but there's very few of them around - so it's a fair assumption that if there's a cradle you have Bluetooth.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,533
    Quote Originally Posted by fossie View Post
    The Bluetooth is only discoverable for a short time after turning the ignition on, so you have to turn the ignition on and then search for and pair with it straight away.
    Sep 2012
    16
    does anyone know where you can get the phone that sits in the cradle ??
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    Quote Originally Posted by Scottwilliamson View Post
    You buy the cradle that suits "your" phone, ie..if you have an iPhone, you buy the iPhone cradle.
    Cradles can be bought from the dealers for around £100.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Sep 2012
    16
    Where about can i get this iphone cradle ? You are speaking about the cradle that is in the armrest?
    2,163
    Your local Audi dealer, or a forum sponsor Stoke Audi
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    I think your a bit confused mate.
    The plate in your armrest, is what the cradle attaches to.
    So as said, you need the cradle that suits your brand phone, and as advised already by me and B5NUT, you can buy it from your local dealer, or from Stoke Audi on this site.
    Hope that helps fella.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Or you could just read your owner's manual, as I think I mentioned about six months ago.
  1. Someone crashed into my car
    By imported_VaulterTim in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd March 2005, 21:41
  2. Car phone kit for 2003 A4 Avant-recommendations?
    By imported_larry1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st March 2005, 08:47
  3. URGENT - HELP NEEDED CAR IN BITS
    By S3_MCD in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2004, 23:15
  4. Remote central locking problem!someone please help
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2004, 13:43
  5. Need some help none car related work pranks
    By DaveCav in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2003, 18:39
