Badger5AH Fabrications
Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By sewell10
  • 1 Post By NHN
Thread: Brake wiring
    Sep 2012
    Brake wiring
    Hi,
    I'm new to this so any reply would be appreciated.
    I have just bought a second hand 2006 b6 a4 avant sline and have a couple of problems with the lights at the back and am looking for a wiring diagram. The rear drivers side cluster has had a botch job done on it and I want to fix it correctly but need to know the colors and pin out.
    I think the problem might have come from a toe bar being put on but would like to know what it should be from a drawing.
    Also dose anyone know where I could buy connectors and stuff for the job??
    Any reply/ help would be appreciated as I have posted on another forum without even getting a reply and not sure if I'm going about posts and stuff the correct way.
    Jul 2012
    56
    You should be able to buy the wires and connectors from Audi. As for the diagrams I couldn't tell you as I'm away from home at the moment but I'm sure someone will be along soon to advise you
    Aug 2010
    1,540
    do you have any pics of how it is now?
    normally after market towbars are fitted with scotch locks that break the towbar wiring into the standard loom without cutting it to shreds etc. non of the standard loom wires are actually cut and bodged to the point you cant work out what was what.
    Dec 2010
    223
    Look at the other side
    POLNEESSON likes this.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,467
    and its B7
    Sep 2012
    Hi,
    The other side has only 4 wires one neutral and a live for each bulb this side has several with choc block and stuff. There is also a fault with one of the boot tail light as it always comes on if a bulb is in it so the wiring diagram is what I need to sort it out. I have sourced replacement part of loom and internal light cluster.
    Yes it's a 2006 B7
    27,073
    Why not trace the connections that dont appear to be original & use a meter to work out which feed does what etc.
    Gazthesparky likes this.
  1. Brake wiring fault
    By sobrien1990 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd September 2012, 13:45
  2. brake wiring loom
    By M12RJX in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th August 2012, 11:06
  3. worn brake pad warning on, but pads /wires are ok
    By DodgeT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th October 2006, 20:01
  4. brake pad warning wires??
    By Darthballz in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th May 2006, 23:58
  5. front brake pad wear-indicator wires!
    By imported_tractorman in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2005, 09:55
