AH FabricationsEM Tuning
Results 1 to 9 of 9
    Feb 2012
    58
    Help Bluetooth suddenly stopped working in RNSE
    It was fine 48 hrs ago and now no phone can pick up a signal from the RNSE unit. Can someone advise on how to fix this if possible ? Based in Manchester.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,520
    look in RNS-E menu
    theres a reset for the BT
    mine does it now and again.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,535
    If that doesn't work then removing power from the phone module usually solves it (the phone module isn't in the RNS-E it's a completely separate module).
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Feb 2012
    58
    Quote Originally Posted by PetrolDave View Post
    Thanks for the input people, where is the phone module located so the power can be disconnected?
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,535
    Quote Originally Posted by zollybosher View Post
    Underneath one of the front seats - I think the drivers seat on RHD. Might be easiest to pop the fuse - could be F8 or F39.
    bez101's Avatar
    Jul 2008
    8,520
    but if its been retro fitted it will be behind the rns-e.
    Feb 2012
    58
    It is factory fitted so look under the seat or pop the fusey eh - cheers
    Feb 2012
    58
    Thank You
    27,113
    As above, but if it also doesnt connect via vcds then possibly a module fault.
  1. doh! electric roof suddenly stopped working
    By Alsie in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th February 2012, 20:32
  2. HELP Electric Window stopped working
    By G60DAN in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2010, 22:19
  3. Bluetooth phone stopped working after installing map reading lights
    By tku in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd August 2010, 17:29
  4. Rear washer jet > stopped working > HELP!
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st March 2008, 19:34
  5. LCD Display In Dash Has Stopped Working?? Can Anyone help??
    By A3EDDIE in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2008, 13:26
