Volks AutosJMB Retrofits
    jakeA42T's Avatar
    Oct 2011
    Gravesend
    90
    High flow cat, do I need it remapped to clear the CEL?
    Was told by AMD that it would cost roughly £500 to install the Sports Cat and remap it as it need to be done to clear the CEL, is this true?
    Audi A4 2.0T Fsi S Line Multitronic
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,393
    Follow Brodster On Twitter Add Brodster on Facebook
    If the sports cat is mated to the remainder of the matching sports exhaust then yes it needs to be remapped to take account of the increased air flow which causes the balance of air and petrol mix flowing into the engine to be upset. Although the engine management system will try to compensate by using the sensors on the car to calculate the changes it is quite possible that the increased airflow will cause this mixture to be lean (too much air and not enough fuel). This is where the remap is needed.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    jakeA42T's Avatar
    Oct 2011
    Gravesend
    90
    At the moment I only have a stock exhaust, thought maybe a spacer would help not sure I really want to remap it yet.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,424
    a spacer will keep the light off in most cases
    sometimes they just dont work tho.
    bez101's Avatar
    Jul 2008
    8,424
    Lambda Spacer Angled o2 Sensor Adjustable Extender Exhaust Decat M18 Lamba 90 dg | eBay
    i find this kind works better for the audi
    stright ones are hit an miss.
  1. High Flow Cat - seems an easy job
    By jakeA42T in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd September 2012, 19:14
  2. S3 High-Flow sports cat
    By Booth_S4 in forum Tuning
    Last Post: 15th December 2006, 08:40
  3. S3 High flow cats
    By imported_glen_jai in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd December 2004, 16:11
  4. High Flow Cat Miltek Alternative
    By RAPS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th March 2004, 17:00
