EM TuningAH Fabrications
    stuiwhite's Avatar
    Jul 2012
    Bristol
    52
    Thermostat not opening but not overheating?
    Good morning!
    My Car: 2005 A4 B7 19 TDI SE (115bhp)
    Please understand that I have looked at every Thermostat thread available on the internet (Well that's how it feels)
    I changed my Thermostat Tuesday evening after months of having my temp gauge never going past 70,
    Took car out after and the gauge got to 90 and stayed there which is fantastic!
    I am a very nervous guy when it comes to cooling (Having needed to change 2 thermostats in the past on a MK3 Ibiza Cupra after they malfunctioned)
    I get in the car and drive to get the temp up to 90 and it nevers go's over 90 or drops anymore and my heating is working better than before (Obviously with it allowing the engine to heat up properly now!)
    However i get out every time now and check coolant levels which are always fine and feel cooling pipes to ensure things are working.
    Heres what i find:
    Top coolant pipe (Nearest to touch when looking under bonnet = Very warm/hot
    Reservoir and pipes coming from it = Warm/hot
    Radiator = Warm/hot
    Now my concern...
    Pipe coming from Thermostat housing = Cold?
    Now should i be concerned as if the car was overheating i would get a error right?
    Is this just because my car isnt getting hot enough for thermo to open?
    Do the diesels run a lot cooler and there for the thermo stays shut a lot longer?
    Any advice would be GREATLY appreciated!
    Thanks,
    Stuart
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    783
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    I can confirm first of all that diesel do run alot cooler than petrol engines. If its not going over 90 then personally I wouldn't worry about it the slightest. Coolant temperature is also dependant on driving style too. It'll only ever get so hot in traffic for instance as opposed to driving at speed with air flow coming through the radiator.
    Audi A4 B7 3.0TDI S-Line Sprint Blue
    ~ MTEC DRLs & Sidelights ~ 8000k D1S ~ 19" A6 Le Mans Edition Wheels ~ Eibach Wheel Spacers (5mm F/15mm R) ~ Rear Ambient Lighting ~
    ~ UK Legal Pressed Plates ~ Full Interior LED Lighting ~ Rear Numberplate LED Lights ~ LCR Front Splitter ~
    stuiwhite's Avatar
    Jul 2012
    Bristol
    52
    Thank you, Really appreciate it.
    I guess im being over cautious!
  1. DIS Showing Door Open But Its Not
    By s3bow in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2007, 21:20
  2. Not new, but not been here in ages
    By AlexStanley in forum The Welcome Section
    Last Post: 11th February 2007, 14:06
  3. A3 2.0 TDI Superchip!!! Got it but not 100% happy.
    By danjones in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th June 2005, 20:07
  4. Electric mirrors but not heated?
    By simong in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th June 2005, 00:00
  5. RSTT's, but not RSTT's
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2004, 08:03
