Chris NottJMB Retrofits
Results 1 to 11 of 11
    Dec 2010
    224
    Audi 2.0tfsi boost loss
    Can the forge blow off valve affect boost loss when fitted
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    what forge have you got fitted ?
    the spacer or this 1 AUDI S3 2.0 TURBO FSIT FORGE VACUUM OPERATED DUMP VALVE | eBay
    Dec 2010
    224
    I have the spacer one
    bez101's Avatar
    Jul 2008
    8,525
    you shouldnt have a problem
    but your dv may be ripped
    Dec 2010
    224
    Will have a look what if it has the d diverter valve bez possible turbo fault
    bez101's Avatar
    Jul 2008
    8,525
    how many miles on the car ?
    those turbos are normaly good are you mapped etc
    could be a split pipe.
    Dec 2010
    224
    Only 45000 miles car is surposed to be mapped holds back around 4000 rpm
    bez101's Avatar
    Jul 2008
    8,525
    id be looking at the DV and leaks
    have you had it scanned yet ?
    bez101's Avatar
    Jul 2008
    8,525
    Quote Originally Posted by sewell10 View Post
    hmm it could be a bad map any reciptes for the map ?
    Dec 2010
    224
    Going to order a new valve and see what goes on the car has invoice but it came with the car
    Dec 2010
    224
    Who are the best people to go to . To get a top result
  1. Audi Problems :( black smoke, loss of power, siren/whistling sound.
    By V16 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th April 2010, 20:20
  2. Boost loss help!!!!
    By s3_kev in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd December 2009, 07:59
  3. audi 1.9tdi power loss
    By madmark in forum Diesel forum
    Last Post: 24th August 2009, 10:45
  4. boost loss
    By mad max in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2008, 16:43
  5. what is acceptable boost loss?
    By dultanur in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th March 2007, 18:36
