EM TuningMonster Motorsport
Results 1 to 29 of 29
    Jul 2012
    192
    Intermittent Turbo Audi A4 2.0 FSI
    Hey all,
    I've only had the car since July and over the weekend I covered around 300 miles. (first proper long journey)
    I did two long 100 mile journeys. I noticed yesterday and today that the turbo will sometimes not kick in.
    It was quite quick before in the first and second gear (3rd to 5th rev) , but it doesn't always feel like a turbo now.
    I had my cambelt changed recently (6th August)
    when I went to the car the VAG specialist had the car plugged into the computer and he said that there was a problem with my AC and intermittent turbo - but at the time I had no problems. He then said it is probably because the sensors had been reset when they changed the cambelt, reran the rest (I think and no problems- he did this within minutes)
    This was 3 weeks ago.
    So the first question is what the VAG specialist said is that correct - can the sensors give a false positive?
    I had a read on this forum and see it is a common fault. I need one of those devices to read the fault codes.
    Should I be concerned with this? What could make the turbo intermittent?
    BTW 61K on the clock.
    Jul 2012
    192
    Is there anything in the engine to stop someone from ripping the crap out of the engine and turbo?
    I found myself testing this 10 times today and maybe 4-5 times it had no power.
    I'm thinking perhaps because I was testing too hard, the turbo might have been disabled.
    Aug 2012
    Glasgow/Scotland
    19
    The car will go into limp mode when its not happy. This will limit boost hence it feels like the turbo has stopped working. This can be caused by a whole host of things such as fuelling or boost leak.
    Best thing to do is get it connected to vag com and check for any faults.
    Jul 2012
    192
    Quote Originally Posted by Chris Norman View Post
    thanks
    when it goes into limp mode - will I notice anything on the dash? i.e How do I know it is limp mode?
    Jul 2012
    192
    of course loss of power
    maybe the engine got hot
    I could live with the car like this, but ought to get it checked out I might have bought a lemon
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,470
    it will cut power so you dont **** it up
    hence limp home
    bez101's Avatar
    Jul 2008
    8,470
    Quote Originally Posted by psd99 View Post
    you could live with your car going in to limp loss of power ?
    get a mini
    Jul 2012
    192
    Well not dangerous to drive around like this so in that respect i would be ok
    But i fear that the loss of power will become greater, i see your point so i will get it checked out
    Will see how it drives in the next week though
    Molnboman's Avatar
    Sorry for hijacking the thread. Do petrol cars go into limp mode.....I thought this only applied to diesels?
    Could someone confirm.
    A
    Jul 2012
    192
    I am Fairly sure that
    both diesel and petrol cars go into limp mode
    Jul 2012
    192
    Performance is okay now still fairly powerful
    Just felt laggish after the long journey oh well
    took it to the garage and there
    There was no fault or error from the VAG console
    i saw him running the test
    northernlight's Avatar
    Sep 2011
    56
    Could be the diverter valve. If that was going then wouldn't show up as fault code and would feel like no boost.
    08 2.0 TFSI Quattro SE V2, Milltek RS4 system, RS4 ARB, AMD Stage 1 remap, Xenons, Valcona leather, RNSE, Eibach Pro Springs, Bose.
    dannyboy75's Avatar
    Oct 2011
    Dorset, UK
    91
    Quote Originally Posted by northernlight View Post
    Agreed, if it feels more like 150-160bhp than 200, then it's probably the diverter valve. I had this when I bought my TFSI last year. No fault codes or engine light, but it felt no faster than my previous car (Alfa 156 JTS) when I first got it.
    £50 for a new DV from ebay, and the difference was unbelievable.
    Audi A4 (B7) 2.0T FSI SE Quattro
    Jul 2012
    192
    Thanks guys so how do u diagnose that the valve is a problem?
    dont really know how to fit that valve
    Any guides? Not really engine competent
    dannyboy75's Avatar
    Oct 2011
    Dorset, UK
    91
    For the sake of £50 for the part, I just took a punt and risked it. It was immediately obvious after the new one was fitted that the old DV was knackered - the rubber membrane splits and leaks boost pressure.
    I didn't fit it myself as I'm pretty useless with cars (computers are more my thing), so just got a local mechanic to fit it. From memory it was only an hour's labour or less.
    P.S. AFAIK, the only way to diagnose it would be to remove the existing DV and inspect it for tears in the membrane, if you don't want to risk the £50 on a new part first. The new part should be a revision D, which has apparently been redesigned to be more durable.
    dannyboy75's Avatar
    Oct 2011
    Dorset, UK
    91
    I just dug up my old thread on this subject. TFSI Quattro performance?
    The part number for the DV, if you do decide to buy one, is 06H-145-710-D.
    Jul 2012
    192
    Hey part isnt easy to find
    I seen this though
    #C114 Audi A4 A5 TT Q5 VW Passat Turbo Cut Off Valve 06F145710G 06H145710D | eBay
    That might be a g and not a d
    Where can i get the right part from?
    Jul 2012
    192
    Atuslly this might do GENUINE SKODA AUDI SEAT DIVERTER VALVE 06H145710D | eBay
    The car is an audi 2.0 tfsi 162kw a4
    Jul 2012
    192
    I seen some videos of how to change the valve
    looks doable here
    Jul 2012
    192
    Just really hard to get to
    Underneath the engine
    Check out this video on YouTube:
    HOW TO REPLACE VW AUDI DIVERTER VALVE - VAG DIVERTER VALVE DIY 2.0T - 2.0T DIVERTER VALVE DIY - YouTube
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,243
    Re: Intermittent Turbo Audi A4 2.0 FSI
    Got one sat in the boot of my car, need to get round to fitting it really...
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, S4 alloys, Spacers, Black Optics, Eibachs, RS4 grill and fogs, Fog tints, RS4 ARB, RS4 Gearstick, LCR splitter, Black Calipers, Drilled discs, Debadged, Colour DIS, Bose, Adaptive Xenons/DRL, Black/Silver Audi Exclusive leather, Audi Carbon inlays, carbon difuser/B pillars, RNS-E+/Bluetooth, Cruise, Int/ext light packs, Rain/light sensors, mudflaps, LED plate/side/boot/interior
    Jul 2012
    192
    Are u competent enough to fit it yourself?
    Fancy doing mine too please. Lol
    May 2011
    Glasgow Area-ish
    62
    If its not your Dv try your N75 boost control valve as mine failed and gave similar symptoms.
    Both valves can be bought from Audi Dv around £60 the N75 around £20
    Jul 2012
    192
    Thanks if there was a problem with. 75would the n75
    produce an error code?
    May 2011
    Glasgow Area-ish
    62
    Yeah mine would sometimes throw a code to say the boost limit was not reached.
    brasiliangringo's Avatar
    Mar 2010
    543
    What you need to do is check the Rosstech VCDS user map on here (if you are in the South i can assist) and offer someone a few beer tokens and they will scan your car and reveal specific fault codes eg faulty N75 / run a boost test. That's the 1st place to start.
  28. #27
    Jul 2012
    192
    Thanks already did that please read above
    Wl get the dv changed
    im excited lOl
  29. #28
    Mar 2010
    543
    You make a vague reference to it yes, but from the code the computer provides, reference material on the web will point you to precisely what components to check 1st.
    Eg im not suggesting this is your code but to get an idea of what i mean:
    17964/P1556/005462 - Ross-Tech Wiki
  30. #29
    Jul 2012
    192
    Thanks guys
    The valve has arrived but not fitted yet
    Seen a video on utube but the valve is in an awkward place to get to underneath the car
    So How much should it cost to replace the valve?
    Btw does the valve always work when i use the right foot or will it only kick in certain times?
    reason I say it because initially I always feel a kick and power but after engine been running for a while
    the power feel is different more gradual and missing the kick feel
  1. Has any1 had their Audi A3 2.0 fsi chipped??
    By todd69 in forum General Automotive Chat
    Last Post: 13th January 2010, 00:45
  2. Intermittent turbo?
    By Felon in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th November 2007, 10:08
  3. Audi A3 2.0 FSI Sport
    By ronakc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th March 2007, 09:40
