Volks AutosBadger5
Thread: Avant boot leak
    Feb 2011
    Somerset
    15
    Avant boot leak
    Hi,
    I have had a leak into the boot of my avant for the past couple of months, the water sems to run down the rear sides of the boot and then tracks across and runs down dead centre on the rear of the car under a black stuck on rubber protector.
    Any ideas of common issues other than lights, and rear washer as i've checked and these are fine, the water runs in at quite a rate when i run the hose over the rear of the car. Are the boot seals prone to getting water under them as it was damp in amongst the grey gunk when pulled it off.
    A4 Avant 2.7 tdi.
    Stage 1 Remap.
    HerefordQuattro's Avatar
    Hereford
    303
    bit of a bump to see if you resolved this?
    my a6 avant is leaking onto the cd player in boot cubby hole
    A6 Avant 2.5tdi Quattro Sport 220bhp 458Nm 6 speed Manual
  1. Avant boot leak
    By Mike B in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th March 2011, 17:41
  2. S-Line Avant boot spoiler?
    By FrankG in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th August 2006, 10:04
  3. Avant boot open!!!
    By WilkoS3 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th June 2006, 13:26
  4. Allroad/A6 Avant boot tray
    By gav210770 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd December 2005, 20:07
  5. AVANT BOOT TRIM
    By ivor1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th November 2004, 12:42
